Old 09-27-2012, 12:14 AM   #1
Just1More
Member#: 319078
2005 STi
Default Someone compare my 2 ROM's to look for driveability problem?
So i've added some recent mods(ECBS, 3 bar MAP, more boost, etc..) to my already modified car, the tune that it came with was said to be way out of whack by my tuner, so he started with a known good ROM from a car he tuned previously and went from there. I am now making more power, more safely than before, he knows his stuff. Unfortunately his knowledge comes at 75 an hour...so here I am. The power is great, i only need help with very low throttle position/light load stumbling it has acquired since he tuned it. My old map was smooth as butter while easing into the throttle and this new one not so much. He spent 2 hours on it last weekend with success, but it needs more work. I know he hasn't compared the two ROM's, only played with the current one.
The issue:
When i ease into the throttle after a gear change(or starting out), i can watch the LC1 wideband and it will be fine(shooting for 14.7), go lean into the low 16's as the car stumbles and bucks slightly, then chug through it and go rich(12-14.0ish), just like it should. It's the lean spot that hesitates, not rich.
I can Email them to someone with more experience than I do, or if somebody feels like naming the tables i need to look at(i won't blindly change stuff, no worries), then i'll follow that route. I am just starting to look them over, so far comparing tip in enrichment and the like. Thanks guys!
Just1More is offline   Reply With Quote
Old 09-30-2012, 02:56 PM   #2
Just1More
Member#: 319078
2005 STi
I upped the low throttle position tables like 4% and it seemed to help, but it still bucks sometimes. I'm checking for vacuum leaks today just in case, not to mention the injectors are stock with the tips cut off(perrin modded), so the idle is wonky and could be contributing to my problem
