Old 10-25-2012, 06:24 PM   #1
xlaterdaysx
Member#: 285807
2011 WRX 5-door
Default 2011 wrx stage 1 93 oct mtv 300
Ive been watching my af learning get more fluctuation lately, and I'm not sure why.
Im all stock, nothing I can notice is wrong. But these logs dont look as proper as they used to... will someone take a look...
https://docs.google.com/spreadsheet/...FFYbU1Bd0F0a0E
xlaterdaysx is offline   Reply With Quote
Old 10-25-2012, 10:07 PM   #2
superacerc
Member#: 317679
2009 2.5XT/20G
Metallic Black
Its not bad. Log a/f correction next time to get a better idea. Should be 0 at 100% throttle. Takes a while to learn. Less than 5% learning is fine. Under 8% is mildly acceptable.
superacerc is offline   Reply With Quote
Old 10-26-2012, 10:04 AM   #3
Cobb Tuning
Member#: 4803
There's no issue there. You are fine as long as you are within around 0 to +/- 5% for each value (you can view each individually via live data or logging by looking at A/F Learning 1 A,B,C,D). +/-5% TO +/- 8% is somewhat borderline, while outside of +/- 8% probably indicates a mechanical issue that is impacting fueling.
Installing the AccessPORT, reflashing a map, resetting the ECU, or disconnecting the car's battery will clear the A/F Learning 1 values and they can take a bit of driving before they populate more accurately.
Bill
