Old 09-28-2012, 02:08 AM   #1
2JZ
Member#: 291949
Default EJ257 swap questions: wiring & subframe
Doing a ej257 swap on my saab 92x 2.5i
I got the ECU immobilizer + keys
The Ej257 I am looking to buy has the Engine harness, and i found a dash harness at a junk yard for $30.
Is the engine + dash harness enough, in junction with my stock 2.5i harness? (Splice everything together)
Do i need a 04-07 STi front subframe for the swap?
Thanks
2JZ is offline   Reply With Quote
Old 09-28-2012, 04:08 AM   #2
AKGC8
Member#: 1305
2000 Impreza
You'll need a GD turbo crossmember that has the same steering rack mounting as your car. They changed around 05 on the STI, not sure about the WRX.
The only thing swap related you'll be missing outside the engine and dash harness is the wires going back to the fuel tank and the fuel pump controller mounted in the trunk of the car. You'll have to get the controller with it's connector and a wire pigtail. That can be wired into the dash harness and then splice into the SAABs OEM wires going back to the pump or just run new wires. You'll definitely need an upgraded pump too.
AKGC8 is offline   Reply With Quote
Old 09-29-2012, 06:39 PM   #3
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
The Saab should already have the new style mounting points, IIRC they actually got them before the WRX did.
Old 09-30-2012, 04:01 AM   #4
2JZ
Member#: 291949
Thanks for the reply!
What about subframe? Will the exhaust clear (i'm doing a full custom exhaust anyway).
