#1 |
Member#: 176517
Vehicle:2004 STi JBP |
While installing coolant crossover pipe on my engine (2.5) after head gasket job, one of the bolts wouldn't get tight and when I removed it the threads from the block came with it. What are my options here? Motor is out of the car and I'm now at a stand still on my build.
![]() Any advice would be great! Thanks, Chris
#2 |
Member#: 296705
NWIC
Vehicle:05 STI Black |
Retap it and helicoil all u can do. Maybe put a stud there if all else fails.
#3 |
Member#: 176517
Anyone ever use this? permatex thread repair
#4 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
get a real machinist to re-tap it......it's not the end of the world... but it suuuuuuuuucks.
A real machinist and get it done no probs. |
#5 | |
Member#: 290592
TXIC
Vehicle:2006 WRX Wagon 2004 WRX Wagon |
#6 |
Member#: 329319
I would just play it safe and re-tap with helicoil. Better to do it right now rather than taking the chance that you may have to do it again...
#7 |
Member#: 175427
South East
Vehicle:2005 STi Aspen White |
helicoil.
it is what it is... it sucks... but oh well. |
#8 |
Member#: 176517
Well, I've decided to go the helicoil route. Does anyone know the thread pitch of these bolts? I'm guessing 1.0 pitch but i dont have a pitch gauge. and the 1.0 nut I threaded it into felt a little loose. Also I wasn't able to even find a 1.25 helicoil set, so my guess it that it's 1.0 pitch
#9 |
Member#: 331579
SCIC
Vehicle:2006 Impreza WRX STi Gray |
Go to NAPA auto parts, thats where i got mine. They are pricey but thats one place in case you cant find them in your regular auto parts stores
#10 |
Member#: 219717
South East
Vehicle:05 FXT Dom2.5R 4EAT FTW!!!! |
Any auto parts or hardware store can tell you what the thread pitch is. Just make sure to get the right depth Helicoil or practice at the 2 coils one hole method a few times because it can be a biotch.
#11 |
Member#: 232430
RMIC
Vehicle:555 I haz 5 Subarus GC8/GF/SG/GD sedan & wag |
its a 6mm bolt, cant remember the pitch though. I want to say its 1.25 though, if i was at the shop today I could tell you, but im not.
you didnt need to take the crossover off to do the HG's though..... unless you were just changing the seals for good measure. Still sucks |
#12 |
Brain Stew
Moderator Member#: 4562
NWIC
Vehicle:1998 Forester,lifted 1975 VW Westfalia tin top |
M6x1.25
Happens pretty frequently and a helicoil will work fine. If you want to be a baller you can get some of those pimptastic threadserts, but I'm always leery about drilling into the block. |
#13 | |
Member#: 176517
I did drill it out and helicoil it and it worked good. Thanks everyone for the help! |
