Old 12-01-2012, 03:38 PM   #101
tidalWRX
Member#: 339413
2013 WRX
Blue Pearl
I'm planning on getting sway bars on my car when I can, next upgrade I need.
tidalWRX is offline   Reply With Quote
Old 12-22-2012, 12:48 PM   #102
wrxmike
Member#: 13800
2013 Impreza Sport
which sway bars fit the '12-'13 imprezas?
more specifically will the Impreza STi Sway Bar Rear 2010-2012 19mm fit?
wrxmike is offline   Reply With Quote
Old 12-22-2012, 03:19 PM   #103
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes, I have one installed
Old 12-22-2012, 07:51 PM   #104
wrxmike
Member#: 13800
2013 Impreza Sport
Nice. Does it make a difference?
nevermind. found some threads on it. apparently makes enough of a difference in understeer and cornering to make it worth it.
Old 12-22-2012, 08:55 PM   #105
Zeeper
Member#: 299286
2015 WRX CVT
Since someone asked, there are urethane mudflats that are 1/3 the cost of Rally Armor.
I just ordered a set of the 'simplified' (more my style, the original look a bit oversized)
http://www.ebay.com/itm/321026873742...84.m1497.l2649
www.Flapatax.com or search for flapatax on ebay when the above link is dead.
They sell two styles, pictured below, both styles are on ebay or their site, along with full mounting hardware and instructions.
http://www.subaruforester.org/vbulle...09/index2.html
This is cross posted from a different thread, but I see people are discussing them here. I almost pulled the plug on the Rally Armors, but these look pretty much the same, stiff urethane, and 1/3 the price. Nice reviews on the internet from other subaru owners, if that matters to you.
Zeeper is offline   Reply With Quote
Old 12-22-2012, 11:58 PM   #106
bettrave
Member#: 340852
2013 Impreza "base"
Is the block heater worth it?
At the dealer, with installation and taxes, it would cost me around 300$
bettrave is offline   Reply With Quote
Old 12-23-2012, 06:34 AM   #107
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I think the answer to that question might depend on where you live. I live in western NY, and don't think it gets cold enough here to justify block heaters/battery heaters/etc. I've never had one on any car I've owned, and don't plan on starting now.
I expect many of our Canadian forum members would say it's a necessity.
sgoldste01 is offline   Reply With Quote
Old 12-23-2012, 10:48 AM   #108
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
The bolded sentence also applies to us Canadians.
I live in Vancouver. Unless you're the kind that feels ultra-protective of your car, it's not necessary for a block heater or battery heater here. Go about 1-2 hours into the interior, and it's probably a bit more justified towards getting such accessories.
lymphomaniac is online now   Reply With Quote
Old 12-23-2012, 01:27 PM   #109
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I found it for 88 online plus a few gaskets and some extra coolant just in case I came in at under 140 installed in my garage
I think it is worth it, car warms up much faster, under 1 mile at 10f
Old 12-24-2012, 08:03 AM   #110
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
I live in Ontario and this morning the temp is a blistering -15 C without windshield. Yeah in most part of Canada you do need a blockheater. Quite often new cars come with the bh already installed but this subbie didn't. Can't remember what the dealer charged me.
Caocao is offline   Reply With Quote
Old 12-24-2012, 11:55 AM   #111
WStrembitsky
Member#: 323877
2012 Impreza Limited
Stupid Ontario and your stupid warm weather.
WStrembitsky is offline   Reply With Quote
Old 12-25-2012, 12:05 AM   #112
bettrave
Member#: 340852
2013 Impreza "base"
How long should it be plugged?
Old 12-25-2012, 12:14 AM   #113
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Temperature starts to level off after about 2 hours.
Commander Keen is offline   Reply With Quote
Old 12-25-2012, 01:47 AM   #114
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Did that hold true for any outside temp?
Old 12-25-2012, 12:30 PM   #115
Commander Keen
Member#: 319157
Mostly. The block heater gets the engine X degrees warmer than ambient. The temperature difference between running the heater overnight and running it for the two hours before you take off is small. The rest is wasted energy.
Old 12-25-2012, 12:46 PM   #116
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have been running mine for 3 hours.
The only thing I don't like about the block heater is that the car will start, then the rpm well bounce a bit and then idle high(but not as high) must be because of all the emission stuff is not to temp?
Old 12-25-2012, 02:09 PM   #117
Commander Keen
Member#: 319157
It might have to do with some areas of the engine being warmer than others when you first crank it. On mine, temperature readings fluctuate a bit as the water pump starts running, then the engine calms down after about 30 seconds. I don't think it's cause for concern.
Old 02-22-2013, 12:42 AM   #118
austriker
Member#: 315079
2011 Impreza Outback
Silver Bullet
So Im looking at adding the following (just got an 11 impreza outback this week):
oem bug/hood guard/deflector
flapatax mud flaps
tint windows
then:
window vent deflectors
seat covers
weathertec mats to replace my sub weather maps
Then hopefully in a few months Ill have some cash saved up for the sub.
austriker is offline   Reply With Quote
