Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 09-28-2012, 01:21 PM   #1
fox_212
Member#: 322902
2003 16G-XT'd WRX
Default IAT relocation questions
Hey all
I'm planning on relocating my IAT sensor to my intake manifold (recommended by tuner). I'm going to use an auxiliary manifold temp sensor rather than hack up an old MAF and take the thermistor out, etc.
2 questions:
1) what manifold temp sensor should I use? I'd like to just grab one from NAPA, but there are literally dozens. Does anybody know of a specific one that works better than others (maybe faster response, idk)?
2) where exactly do you think I should put it? Close to throttle body or elsewhere? My tuner said I could even mount it in my tmic, but I've not heard of anyone else doing that.
I'm doing a stage 3ish build with a blouch 16g-xt, 650cc injectors, and other supporting mods.
So, whaddaya think? Many thanks in advance
fox_212 is offline   Reply With Quote
Old 09-28-2012, 01:29 PM   #2
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Put it where he recommends doing so...he is the one tuning your setup. I just hope he is a reliable. Why relocate for a 16g if you don't mind me asking?
wrxlaunch is online now   Reply With Quote
Old 09-28-2012, 01:39 PM   #3
fox_212
Member#: 322902
2003 16G-XT'd WRX
Ya they said in the intercooler, which just seemed weird, but i suppose it makes sense for a few reasons. I'm also trying to make sense of exactly where in the intercooler based on my phone conversation
The reasoning is because it gives a more accurate, realtime measurement of intake air temp. I realize its probably unnecessary since I will be running cold air intake and it won't heat soak that much. But hey, I'm not one to refute the advice of the Dom
Thanks for the advice, keep it coming!
Old 09-28-2012, 01:44 PM   #4
biodude
Member#: 271720
I was just asking Dom about this recently. I know he likes relocating the IAT. Put it as close to your TB as possible. The IC output flange area would be an easy spot.
I plan on doing the same thing fairly soon and am curious to see what kind of difference it will make.
biodude is offline   Reply With Quote
Old 09-28-2012, 01:52 PM   #5
fox_212
Member#: 322902
2003 16G-XT'd WRX
Ya that seems like a good spot. However I have heard that putting it after the throttle body can help mediate temperature swings. Where you puttin yours?
Did Dom mention what specific sensor they usually use? Does it matter?
Old 09-28-2012, 02:36 PM   #6
biodude
Member#: 271720
just for ease of install, I'll be putting in my top mount on the bottom of the flange as close to the hose connection as I can. I don't see there being that much of a diff in temp from there as opposed to putting it after the TB on the intake manifold. If I was running a front mount IC, then I would put it right near the throttle body.
As far as sensor, I was going with this one
http://www.bmotorsports.com/shop/pro...roducts_id/400
Its just a GM sensor, so Im sure you can source it locally as well. And I never asked him, but the GM seems to be the one I see mentioned most often.
Old 09-28-2012, 02:42 PM   #7
fox_212
Member#: 322902
2003 16G-XT'd WRX
Ya I was having trouble seeing how the post-TB placement thing made sense. I have that exact sensor page open in another window hehe.
When you install yours, could you post pics? It'd be nice for me and others thinking of doing this in the future
Thanks for the quick responses
Old 09-28-2012, 02:52 PM   #8
biodude
Member#: 271720
there's a couple pic sin the speed density thread regarding IAT placement.
http://forums.nasioc.com/forums/show....php?t=2266873
Old 09-29-2012, 12:27 PM   #9
fox_212
Member#: 322902
2003 16G-XT'd WRX
^nice, those are helpful.
One more question: Do you know which of the wires go to the IAT in the stock MAF? ie which wires to use for the new IAT
thanks again
Old 09-29-2012, 01:12 PM   #10
10MTN-bugeye
Member#: 288093
2002 Bugeye
PSM and parking lot scars
I can't remember if it was here or on Romraider, but someone had been using a Honda IAT that had the same scaling as the Subaru oem Maf sensor.
The guy said he had it hooked it up in parallel (for testing) with his oem maf with a switch and had logged it at different loads with little to no variance between the two readings.
I believe the sensors was from a 98-04ish Accord. I had been planning to build one into my spare manifold until I was side track by my driveline swap.
10MTN-bugeye is offline   Reply With Quote
Old 09-29-2012, 01:16 PM   #11
10MTN-bugeye
Member#: 288093
2002 Bugeye
As far as wiring, there should be 5ish(?) wiring attached to you MAF. IIRC two for the Temp, three for the maf.
Old 09-29-2012, 01:18 PM   #12
10MTN-bugeye
Member#: 288093
2002 Bugeye
http://www.northursalia.com/modifica...ng/wrxpin.html
This lists four wiring into maf, I still think there are five.
Old 09-29-2012, 01:31 PM   #13
10MTN-bugeye
Member#: 288093
2002 Bugeye
Here's the pinout from the manual for Impreza RS/WRX 2002-03
Old 09-29-2012, 01:38 PM   #14
fox_212
Member#: 322902
2003 16G-XT'd WRX
awwesome, thanks for that info. I'm gonna do the relocation today
Old 09-29-2012, 01:46 PM   #15
10MTN-bugeye
Member#: 288093
2002 Bugeye
I'd be interested to see some pictures of your install if you could get some. You're putting the sensor in the TMIC, right?
Old 09-29-2012, 01:47 PM   #16
rocketperson7
Member#: 283968
2003 WRX
MBP
There's a casting boss on the bottom of the manifold which is where I'm putting mine.
rocketperson7 is offline   Reply With Quote
Old 09-29-2012, 01:56 PM   #17
fox_212
Member#: 322902
2003 16G-XT'd WRX
Yea I think I'll try putting it on the bottom, close to the IC outlet. I'll take some pics along the way
Old 09-29-2012, 06:51 PM   #18
biodude
Member#: 271720
keep in mind that the GM thermistor is scalled differently than the stock, so I'd get it in and the wires ran back to where you will splice into the maf, but wait until your at MPS for your tune before making the final wire splice.
Old 09-30-2012, 01:45 PM   #19
fox_212
Member#: 322902
2003 16G-XT'd WRX
^good point. What I've actually decided to do is buy an extension harness for the GM IAT sensor and splice that into the MAF wiring. Here's a link to where I found the idea, as well as really good instructions for actually splicing the wires:
http://www.iwsti.com/forums/cobb-str...rt-finish.html
and here is where you can order the extension harness:
http://www.bmotorsports.com/shop/pro...roducts_id/566
Really clean finished product, and gives you the option to use your stock IAT sensor, should you ever want to
Old 10-02-2012, 09:20 AM   #20
biodude
Member#: 271720
I just ordered my new sensor, so hopefully I can find time this weekend to install it as well as try my hand at adjusting for it
Old 10-03-2012, 01:50 PM   #21
fox_212
Member#: 322902
2003 16G-XT'd WRX
FYI, I found more info on the IAT relocation in Cobb's SD tuning guide. While the guide is for SD tuning for 2.5L engines, the IAT relocation on pg 40-41 applies to 2.0L WRX's as well.
http://accessecu.com/support/docs/tu...sity_Guide.pdf
waiting on my extension harness to finish the mod
Old 10-03-2012, 03:00 PM   #22
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
My intake mani it's reversed but I put mine right in the back of the manifold.
Old 10-03-2012, 03:08 PM   #23
biodude
Member#: 271720
nice and clean.. me likey
Old 10-07-2012, 01:39 AM   #24
10MTN-bugeye
Member#: 288093
2002 Bugeye
That manifold is sick. Nice work.
Old 10-09-2012, 07:25 PM   #25
10MTN-bugeye
Member#: 288093
2002 Bugeye
I am envious of this. I have been slowly working on this in my spare time. I'm still not finished porting and shaving my spare manifold. Did you fab the bracket for the FPR, or is that something that's available through Aeromotive? Any plans to mount a fuel pressure sensor in the fpr?
