Old 09-29-2012, 01:03 AM   #1
P8S-WRX
Member#: 14893
2002 Impreza WRX
Default Alternator and ECU
Does the ECU control alternator output voltage? I have replaced the alternator on a 2002 WRX twice, and after a couple of hours voltage jumps all over the place again and eventually the alternator drops off line and fails.
Suggestions appreciated
Steve P
El Paso
P8S-WRX is offline   Reply With Quote
Old 09-29-2012, 11:30 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I think it depends on what model you have. In the later years the ECU was involved with the circuit. Make sure the battery warning light works ok when you turn the key to the Run position. Current flows through it for the exciter circuit. Systems that involve the ECU should have 3 wires going to the back side of the alternator. Others use only 2 wires.
Old 09-29-2012, 12:41 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The '02 is internally regulated in the alternator, no ECU involvement. Make sure the battery is good, check all wiring especially main grounds.
