Old 09-29-2012, 11:37 AM   #1
mrchyes
Member#: 294069
98 Forester
Green
Default forced induction options
hello, I have a 2004 RS N/A with ~150k miles and just got the timing belt, headgaskets done...
I have no intentions of doing any kind of anything to this motor until i can absolutely afford it, in probably more than 2-3 years.
I was just wondering what the options for forced induction on a 2.5 SOHC N/A motor are. I heard about it from a friend and i guess i had just never thought it was even possible.
Flame suit on! hopefully i wont need it
discuss.
mrchyes is offline   Reply With Quote
Old 09-29-2012, 11:59 AM   #2
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Take a look at avo turbo kits for impreza n/a's or raptor superchargers
alt14 is offline   Reply With Quote
Old 09-29-2012, 12:13 PM   #3
mrchyes
Member#: 294069
98 Forester
Green
will do thanks
Old 09-29-2012, 12:20 PM   #4
poly_poly-man
Member#: 262988
2005 Baja Turbo
Regal Blue Pearl
It will most likely be as expensive or more than a ej205 swap, and will give you less power and less reliability. Think long and hard about whether it's really your best option.
poly_poly-man is offline   Reply With Quote
Old 09-29-2012, 12:40 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
There's a forum for that.
Way back in the day there were guys running turbo'd 2.5RSs (before the WRX came to the US) and making more power than the 2.0L WRXs. Obviously the tune has to be right, but if it is, more displacement and higher CR is going to give you more power.
Patrick Olsen is online now   Reply With Quote
Old 09-29-2012, 06:53 PM   #6
mrchyes
Member#: 294069
98 Forester
Green
if i was going to do any kind of forced induction on this RS it would be because Id rather keep my first subaru and have more power, than sell it and get a new car with hidden problems.
That said, the reason id rather go with a RS block and sohc and the higher compression of the RS motor is because i was told higher compression and sohc is better for forced induction.
Is that true? or no?
would it be better to go with a stock STi engine?
maybe i am led astray that the RS 2.5 is better for forced induction power, it seems like it doesnt make sense, but idk.
Old 09-29-2012, 07:57 PM   #7
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
The RS engine is not designed for boost and the STI engine is. I think that's all you need to know in terms of which would be the best overall setup.
chazly413 is offline   Reply With Quote
Old 09-29-2012, 07:57 PM   #8
James2.5i
Member#: 305063
2016 VDUBBB
Is this your DD?
James2.5i is offline   Reply With Quote
Old 09-29-2012, 08:27 PM   #9
mrchyes
Member#: 294069
98 Forester
Green
i am looking at this question in the stand point of the future, in the future this RS will not be my DD, probably a project car. i guess it is too broad of a question to ask, but if the RS engine isnt designed for boost then how have people done it reliably?
Old 09-29-2012, 09:41 PM   #10
alt14
Member#: 271928
2014 WRX Limited
Well what they're saying is that the rs wasn't originally designed with forced induction in mind, therefore no reason for reinforced materials for reliability, however they can be boosted at low pressures and be reliable from what I hear though I wouldn't trust it myself
Old 09-29-2012, 09:56 PM   #11
mrchyes
Member#: 294069
98 Forester
Green
well, i was just wondering thanks for all the info guys..
i guess when the time comes to rethink the engine i will have to decide then
Old 09-30-2012, 10:29 AM   #12
James2.5i
Member#: 305063
2016 VDUBBB
You can reliably do it (within reason of course, 20PSI turbo may be more than what your car can handle long term), but as a DD you'd have to have a backup for when things go wrong, money needs to be saved, or mods take longer than expected.
As a project car though, you could garage it for as long as you want until it's ready. And as long as you keep the psi reasonable, you can reliably upgrade to a turbo or supercharger application.
Is it tuned at all now? You'd be surprised at how a tune can improve a car's performance. Maybe worth looking into?
Old 09-30-2012, 12:46 PM   #13
mrchyes
Member#: 294069
98 Forester
Green
a tune is definitely worth looking into i will probably have headers and an intake soon enough and might flirt with the idea of going to E85, idk what the gains would be, but ive never seen E85 run on a N/A scooby.
