Old 09-29-2012, 12:13 PM   #1
redrex2002
Member#: 118915
2002 wrx
srp
Default 04 wrx motor into an 02 wrx
hello guys i think i might have finally killed my 02 wrx motor with 204k miles. doing a compression check Monday but i have a really bad misfire on cyl. 4 that refuses to go away. luckily for me my boss's nephew just totaled his 04 wrx, and even better he is selling me the entire car for 800 bucks. so my question is is there anything i have to do to swap the motors over? or is it a plug and play kind of swap?
redrex2002 is offline   Reply With Quote
Old 09-29-2012, 12:51 PM   #2
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
The longblock should be the same as yours.
jake
KONKILR is offline   Reply With Quote
Old 09-29-2012, 01:23 PM   #3
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Basically the same car.
Where was the donor car hit? If it was a front hit that engine may be toast. Does it start and run?
Old 10-01-2012, 03:12 PM   #4
redrex2002
Member#: 118915
2002 wrx
srp
my buddy rear-ended someone. the plastic timing cover is cracked but the cam gear and timing belt are in perfect shape.
would the wiring harness and everything else switch over or would i have to re-use the harness off of my motor?
Old 10-06-2012, 06:26 PM   #5
Seattle_WrxWagon
Member#: 334326
Default 04 blocks...
Hi guys I have a 04 wrx wagon with rod knock and I am looking to drop in a 04 sti engine. I have no prior experience with conversion so I was wondering if you guys could give me some tips on things to look out for, pricing ect?
Thanks,
Giff
Seattle_WrxWagon is offline   Reply With Quote
