#1 |
Member#: 280696
Vehicle:2003 Impreza TS Wago SGM |
So, my car is throwing FOURTY ONE codes...Can anyone guess what the problem would be? It's driving just fine. Nothing seems to be unhooked
0028 0082 0083 0026 0077 0076 0196 0198 0420 2016 2017 2021 2022 2009 2012 2008 2011 2004 2006 2005 2007 2227 0126 2229 2228 0958 0957 0955 0883 0882 0880 0817 1601 2100 2111 2504 2503 1462 1463 1026 1028
#2 |
Member#: 305063
Vehicle:2010 Storm Trooper |
Holy crap. That's amazing. My guess is ECU or wiring harness, but it's a bad guess. Good luck in fixing it.
#3 |
Member#: 271928
Vehicle:2007 Impreza 2.5i SE OBP |
..wow, did you try resetting the ecu and driving around for a little to see if some/all come back up?
#4 |
Member#: 280696
Yes. Came back a couple miles later
#5 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
It could be a voltage problem. Check the cables and the alt.
#6 |
Member#: 236927
NESIC
Vehicle:1993 Legacy Sedan 1984 BRAT |
Are those codes current codes or stored codes?
#7 |
Member#: 280696
current. As I said above, I reset the ecu, and they came back a couple miles later. Car is completely stock, no modifications.
#8 | |
Member#: 208052
Vehicle:2004 SGM FXT-6speed *SOLD* 02 PSM WRX |
#9 |
Member#: 280696
Kojak, I'd gladly drive it over to you to take a gander, lol.
#10 |
Member#: 208052
Look under your dash to make sure the green connectors aren't plugged together:
http://www.rs25.com/forums/f72/t1285...odes-help.html |
#11 |
Member#: 280696
They're unplugged
#12 |
Member#: 208052
Check battery voltage as well, could be bad battery.
#13 |
Member#: 280696
Will do! I'll swap the battery that I have in the SVX.
