Old 09-29-2012, 11:19 PM   #1
gurusan
Member#: 258165
2006 WRX Wagon
Default 06 WRX XPT stage 2 log
So it would be great if I could get some feedback on my log. I am running XPT stage 2 map on my 2006 WRX wagon.
I edited the MAF scaling tables to accommodate for my short ram but according to learning view it looks like the ECU is still adding fuel to compensate.
I also did a 3rd gear pull and heard an audible detonation sound at 6k rpm so instantly backed off the throttle, and sure enough looking at the log there is -3 degrees FLKC.
I'm running 92 octane E10, I live at sea level to 500-1000 ft (beaverton and portland, or) and my mods are:
-OBX short ram intake (cobb sf knockoff sort of)
-catless TBE
My questions are:
-Should I continue to work on scaling my MAF or should I ditch the intake altogether and go back to stock airbox. The IATs do fluctuate quite a bit since it's a short ram, but I really do love the sound of the turbo and BPV.
-What should I do to address the -3 degrees FLKC? Again, ditch the intake and reset the ECU? Or pull timing above 6K? Adjust WGDC and target boost to reduce boost at higher RPM?
Thanks in advance
https://docs.google.com/open?id=0B8B...k9obnFLR1Zla2M
gurusan is offline   Reply With Quote
