Old 10-19-2012, 11:52 AM   #1
cmiovino
Member#: 134005
2004 WRX Premium
Default Weird idle issue
4EAT, Complete Cobb Stage 2, 91 Oct Map, 93 oct gas. Happens with any gas brand, tried swapping around. Plugs brand new. Oil with about 2-3k miles on it.
If I'm stopped at a red light, the car idles just fine. Then all of a sudden the RPMs slightly rise and the 2nd fan kicks on. It run for a few seconds then shuts off. A few seconds later, the fan kicks on again, etc.
Keep in mind this is in about 40-50 degree morning temps... or 60's ish we've been having in the evenings. I've never had this happen with my old '98 Impreza and know when the additional fan should be kicking in. It seems to kick on a lot more than normal.
Car runs completely fine. It just bugs me that it does this.
Old 10-19-2012, 12:02 PM   #2
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
loosen your cruse control cable. do a search for high idle, you'll see what I'm talking about
jayman4312 is offline   Reply With Quote
Old 10-19-2012, 02:03 PM   #3
cmiovino
Member#: 134005
2004 WRX Premium
I did read about that.. probably should have been more specific. Mine only rises about 200-300 RPMs, never going above 1k RPMs. Seems like many of the people with the CC issue have theirs going up to 2000, 4500, etc.
Either way, I'll check it.
Old 10-19-2012, 02:04 PM   #4
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
true, but many people are also manual/5speed and when that happens they are in neutral, you are not.
Old 10-19-2012, 02:15 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Is the A/C or defroster on when this occurs?
Old 10-19-2012, 02:16 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
Duh. Thanks.
You figure after 6 years of modding 4EATs, I would have thought of that...
That's most likely the issue. I'll check it out.
Old 10-19-2012, 03:04 PM   #7
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
Originally Posted by cmiovino View Post
Duh. Thanks.
Haha, sometimes it just takes an outsider to look at a problem to see something simple you overlook. Hope it works.
