Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 09-30-2012, 04:26 PM   #1
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
Default STI Rear seat removal question
Friend only has one key. hit the valet switch on his trunk by accident so he cant open trunk from release or with key. has to go through back seat now. has the back seat out, now there is a black plastic panel stopping him from getting back in there to release the trunk. how do you remove this?
VTSubieRS is offline   Reply With Quote
Old 09-30-2012, 05:25 PM   #2
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Pretty sure you have to remove it from the trunk. If you punch it out though there's no real harm done as you will just have that panel missing. It is a thin honeycomb plastic panel and when I swapped rear seats in my wrx I left a hole behind the seat for that reason (and skiing). Replacements aren't expensive either if he must have trunk aesthetics in line.
Kick that s*** out.
JavaBot is offline   Reply With Quote
Old 09-30-2012, 08:44 PM   #3
emazz104
Member#: 281811
04 WRX
World Rally Blue
You can't pull the release with some sort of stick and a flashlight by just going through the pass though (or with the seat out?)
Seems like you should be able to.
Anyways, I believe you can just peal up one side of the plastic without wrecking it. I haven't tried though. Good luck.
emazz104 is offline   Reply With Quote
Old 10-01-2012, 07:21 AM   #4
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I've had to crawl in there many times for this same reason. I haven't done it for so long now but I could've sworn you could unbolt everything behind the seat and get in there.
