Old 09-30-2012, 08:01 PM   #1
Subie2Go
Member#: 237699
Exclamation Starter will not engage
I have a '93 Loyale that had a push button 4WD 5 MT in it and I replaced it with a lower mileage engine and transmission (my engine died and I swapped in a D/R 5 MT).
The engine was from an '89 Loyale FWD automatic.
The Transmission was from an '87 GL.
Got everything swapped over, ground wires are checked, starters are checked and working and wires are connected, power works, battery is charged.
Problem: When trying to start the car, the starter will not engage and will not turn the engine over.
Any ideas?
Thanks.
Subie2Go is offline   Reply With Quote
Old 09-30-2012, 08:45 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Does the relay and/or solenoid close?
Old 10-01-2012, 12:38 AM   #3
Subie2Go
Member#: 237699
i am going to try to check the relay, the solenoid does click, but does not engage the starter.
Old 10-01-2012, 10:00 AM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
If the solenoid clicks then the relay is obviously working. Check voltage after the solenoid (might have to remove starter to bench test/disassemble). Should be close to voltage going into the starter. If there is a large voltage stop across the solenoid due to a high resistance (burned/broken contacts) then it is not enough to throw out the drive on the starter. At this point, a replacement starter is probably the most economical fix, just verify good voltage to the starter.
Old 10-03-2012, 02:16 PM   #5
Subie2Go
Member#: 237699
So i was able to go through everything and diagnose it as a bad battery cable, both ends looked good, but the center was pretty corroded so I replaced that and it started right up.
thanks again for all the help and comments. In the long run it think it will be better off since i now have the right information to check for other solutions if something else were to cause this to happen again.
