Old 09-26-2012, 08:38 PM   #1
BillBall
Member#: 331548
Default Clutch adjustment?
I am new to the subie world, I have a 2002 Wrx hatch. My clutch is engaging at about the pedal being half way released. Is there an adjustment for the clutch? I know it is a hydraulic assemble but can anything be adjusted? Thanks in advance for any help!
BillBall is offline   Reply With Quote
Old 09-26-2012, 08:53 PM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
Best bet maybe bleed the clutch. Not much adjustment can be made besides new clutch.
Andrewxxcarlson is offline   Reply With Quote
Old 09-26-2012, 08:56 PM   #3
kakdaman
Member#: 245117
2005 wrx
aspen white
Subarus are known for there high clutch engagement. As far as I know there is nothing you can do.
kakdaman is offline   Reply With Quote
Old 09-26-2012, 10:17 PM   #4
BillBall
Member#: 331548
Ok thanks guys! Does the cylinder use brake fluid? I will be bleeding it this weekend
Old 09-27-2012, 03:32 AM   #5
Andrewxxcarlson
Member#: 316415
2006 WRX
Dot 3 sir.
Old 09-27-2012, 04:19 AM   #6
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Didn't someone make a block/spacer thing to move up the bottom of the pedal travel?
Counterfit is offline   Reply With Quote
Old 09-27-2012, 11:15 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
yes, some bright lightbulb on here glued a wood block under the pedal to limit the downward travel. don't do it... Op, yours sounds entirely normal. I wouldn't even bother bleeding it, there is no reason to touch it unless it has been worked on recently.
rkramer is offline   Reply With Quote
Old 09-27-2012, 02:52 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You can adjust the clutch master cylinder linkage to adjust clutch engagement point.
Old 09-27-2012, 03:19 PM   #9
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
worst case scenario, you have a slave going out (which isn't that uncommon in Subaru's either).
-Mark
APM Tuned is offline   Reply With Quote
Old 09-27-2012, 03:50 PM   #10
Counterfit
Member#: 124254
"The Scoobinator"
Old 10-02-2012, 12:44 AM   #11
BillBall
Member#: 331548
Where is this adjustment located, up under the dash or in the engine compartment? Thanks again everybody
Old 10-02-2012, 03:35 PM   #12
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
1) Unbolt accl pedal
2) Use 12mm wrench to loosen nut in picture.
3) Depress clutch (wiggle it by hand) as you turn the clutch master cylinder rod by hand
4) Tighten the 12mm nut
5) Bolt accl pedal
Key here is depressing the clutch back and forth to get the rod to turn, otherwise your fingers will just slide on the rod. Try to adjust the clutch pedal slightly below the brake pedal and report back.
V8 GTFO Lesbic WGN is offline   Reply With Quote
