Old 10-01-2012, 02:12 PM   #1
IVIattIVIan
Member#: 295602
Default 300+hp trap speeds?!
Lets hear your guys/gals' thoughts. In a debate of my power and trap speeds and curious now!! Go!
IVIattIVIan is offline   Reply With Quote
Old 10-01-2012, 02:26 PM   #2
IVIattIVIan
Member#: 295602
Old 10-01-2012, 02:26 PM   #3
IVIattIVIan
Member#: 295602
Tuned at 312awhp/292awtq
Old 10-01-2012, 02:32 PM   #4
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Just curious on what dyno this was on? There's a thread around here somewhere showing what hp should = trap speed. Its all relative though depending on which dyno and correction factors
wrxsubiemod is offline   Reply With Quote
Old 10-01-2012, 02:39 PM   #5
IVIattIVIan
Member#: 295602
Mustang dyno. I don't recall corrections. Ill post my dyno sheet up later
Old 10-01-2012, 05:40 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
trap looks very low for 300whp. Did you trap alot higher on any other runs? How hot was it at the track?
I'd expect about 107-110+ trap speeds with 300whp
Old 10-01-2012, 05:49 PM   #7
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
What does it weigh?
OppositeLock is offline   Reply With Quote
Old 10-01-2012, 06:25 PM   #8
IVIattIVIan
Member#: 295602
Originally Posted by OppositeLock
What does it weigh?
Stock 04 wrx. So 3200lbs
Old 10-01-2012, 06:37 PM   #9
IVIattIVIan
Member#: 295602
Weight with the tuner is 3375lbs
Maximum power before wcf is [email protected]/83.9mpb
Maximum torque before wfc is [email protected]/62.2 mph
Old 10-01-2012, 06:39 PM   #10
IVIattIVIan
Member#: 295602
102 mph was my highest for the night.
Old 10-01-2012, 07:40 PM   #11
2000subie
Member#: 207638
2004 WRX
Yellow
I trapped 106 with my 240whp set up, and 112 with 290whp. Both with 1.7-1.8 60fts, my current 375whp set up trapped 117 with a 3.2 60ft. A 2.0 and a 30r is terrible lag with no launch, should be low 120s with a decent launch. So you should expect around 110mph at least imo. I'm at about 4300ft altitude also.
2000subie is online now   Reply With Quote
Old 10-01-2012, 08:21 PM   #12
xxscaxx
Member#: 86459
2013 BRZ
Agreed.
xxscaxx is offline   Reply With Quote
Old 10-01-2012, 08:21 PM   #13
IVIattIVIan
Member#: 295602
Hmmmm. I wonder why I'm running lower then i should be.....
Old 10-01-2012, 09:08 PM   #14
4Warned
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
112.14 mph
326whp/357wtq via Virtual dyno
4Warned is offline   Reply With Quote
Old 10-02-2012, 12:46 PM   #15
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
I put down 296whp on a Dynojet with a stock weight 04 STI and trapped 107.
FCmaniac is offline   Reply With Quote
Old 10-02-2012, 01:47 PM   #16
RancerEvorution
Member#: 235190
2011 STi
car #82
i put down 335/420 on TheShopCT's dyno 93 pump
best trap was 110.32
i think i would put down 300 on a mustang dyno... TheShop's dyno reads similar to a dynojet
stage 2 + el header + ewg
RancerEvorution is offline   Reply With Quote
Old 10-02-2012, 03:33 PM   #17
x99percent
Member#: 27108
2004 STi
2004 A4
2004 STi, running a small FB Green setup (IWG, 7cm, 2.4" inlet)
Put down 320whp on a low-reading Mustang dyno (correction factor = 1)
Ran 11.9 @ 115.9mph
This was back in 2005/2006, but it counts, right?
x99percent is offline   Reply With Quote
Old 10-02-2012, 04:01 PM   #18
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
You're probably not putting down 300whp if you are trapping 102mph (best).
Fierysun is offline   Reply With Quote
Old 10-02-2012, 06:29 PM   #19
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I no longer have the graphs or the car but putting down 300whp/330 lb-ft on airboy in an "03 hybrid WRX I would consistently trap 112mph with one 113mph pass
Old 10-02-2012, 06:54 PM   #20
FCmaniac
Member#: 142029
2013 Forester
^^ wow, great traps for that whp
I'm curious as to the weight of bugeyes vs. STI's. I've read about bugeyes trapping pretty high with less whp.
Old 10-02-2012, 07:05 PM   #21
eg33GC
Member#: 206851
56 Belair
Pro Street
yeah for sure
114.5mph trap here, ~320ish
eg33GC is offline   Reply With Quote
Old 10-02-2012, 09:16 PM   #22
IVIattIVIan
Member#: 295602
I don't get it.....
Old 10-03-2012, 12:31 AM   #23
subenerd
Member#: 72630
2004 STi
Ran 12.8 @ 109. Stock turbo, catless, intake, 91/100oct mix, put down 307whp / 350ft-lbs on Ed's old dyno software.
subenerd is offline   Reply With Quote
Old 10-03-2012, 12:56 PM   #24
IVIattIVIan
Member#: 295602
Thank you for all your input!!
Old 10-03-2012, 03:49 PM   #25
05bluesti
Member#: 251804
05 WRB STi
its cause you are slow, you should have gotten an sti, then youd be fast like everyone else, you are such a noob
05bluesti is offline   Reply With Quote
