Old 10-03-2012, 04:04 PM   #26
IVIattIVIan
Member#: 295602
Originally Posted by 05bluesti
its cause you are slow, you should have gotten an sti, then youd be fast like everyone else, you are such a noob
A kick for you in the starfish sir!!!
IVIattIVIan is offline   Reply With Quote
Old 10-03-2012, 04:41 PM   #27
05bluesti
Member#: 251804
05 WRB STi
thank you, may i have another?
05bluesti is offline   Reply With Quote
Old 10-03-2012, 04:58 PM   #28
IVIattIVIan
Member#: 295602
Coming atcha!!!
Old 10-03-2012, 05:36 PM   #29
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
I was wondering the same as OP. My car put down 335/375 on a mustang dyno, 110 degrees. Before wcf it put down 255/290, that has me worried that I wont trap over 106ish. Hopefully the cooler weather bumps up the power?
ByeBye4g63t is offline   Reply With Quote
Old 10-03-2012, 05:53 PM   #30
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
All other things equal, the cooler the temp, the more the powah. Just log to make sure your IDC isn't too high and you're still safe.
FCmaniac is offline   Reply With Quote
Old 10-03-2012, 07:08 PM   #31
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
OP, why don't you post your full setup as well as dyno graph? Also, at what RPM are you shifting at?
Fierysun is offline   Reply With Quote
Old 10-03-2012, 11:16 PM   #32
IVIattIVIan
Member#: 295602
Full car setup!
Grimmspeed catless uppipe
Tial 38mm EWG
vf39
FiveO 850cc injectors
Fmic
Aem cai
Invidia q300 tbe
255walbro fuel pump
1 cooler spark plugs
All on 91 pump gas
Old 10-04-2012, 01:15 AM   #33
Fierysun
Member#: 82745
2005 Subaru STI
Full car setup!
Tial 38mm EWG
vf39
Fmic
Aem cai
Invidia q300 tbe
255walbro fuel pump
All on 91 pump gas
You're probably seeing around 250whp on a 2.0L with that setup. Honestly, you didn't need 850cc, EWG, FMIC or 1 step cooler plugs with a Vf39.
You would have made around the same power with 650cc, IWG, stock heat range plugs, and an STI TMIC.
Old 10-04-2012, 02:58 AM   #34
CmrnDrgn
Member#: 230605
'02 Bugeye
Under construction
Agreed, I run a vf-39 on the 2.0 with 650cc dws injectors, sti top mount, aem intake, full catless exhaust and walbro pump and made 300hp/270-trq. Those supporting mods are over the top. While you have them you should step up the turbo size and get re-tuned
You're probably seeing that low of a trap speed as a combo of a slow launch and/or the dyno reading high.
CmrnDrgn is offline   Reply With Quote
Old 10-04-2012, 07:18 AM   #35
wrxlaunch
Member#: 181298
What's your track time and trap?
wrxlaunch is offline   Reply With Quote
Old 10-04-2012, 09:17 AM   #36
IVIattIVIan
Member#: 295602
I did the mods with plan of a 20g in the near future. 13.2 @102 mph
Old 10-04-2012, 12:55 PM   #37
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Matt, on that same dyno, i was @ 468 with CF, and trapped 119.
12.12 @ 119, IIRC. crappy launch, crappy tires, spinning the rear thru 2nd.
Z0rr0 is offline   Reply With Quote
Old 10-04-2012, 02:41 PM   #38
IVIattIVIan
Member#: 295602
Then ppl will probably say your not making close to 468......
Old 10-04-2012, 02:59 PM   #39
mtarr07
Member#: 246990
2010 Wrx
This. There have been stock turbo STI's and 2009+ wrx's trapping 116-117mph. You're probably making over 100 less whp than that dyno is suggesting.
mtarr07 is offline   Reply With Quote
Old 10-04-2012, 04:55 PM   #40
Fierysun
Member#: 82745
2005 Subaru STI
That Correction Factor grossy inflat the numbers. I would disregard it completely and look at the uncorrected #'s as what you are potentially making.
In addition, why is the tune cut around 6.7K? I would have it tuned to 7k-7.1K.
Old 10-04-2012, 05:15 PM   #41
IVIattIVIan
Member#: 295602
What Is the point of correction factor then.........?
Old 10-04-2012, 05:17 PM   #42
IVIattIVIan
Member#: 295602
Like saying bhp versus whp!?
Old 10-04-2012, 05:31 PM   #43
bilt2run
Member#: 134211
Correction factors on dynos are calibrated for Naturally aspirated cars
bilt2run is offline   Reply With Quote
Old 10-04-2012, 05:34 PM   #44
cronic
Member#: 9749
It makes your e-penis bigger, until you go to the track.
cronic is offline   Reply With Quote
Old 10-04-2012, 08:11 PM   #45
IVIattIVIan
Member#: 295602
HHahaha apparently!!!
Old 10-05-2012, 10:58 AM   #46
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Sounds like you're at elevation so the dyno correction factor for a turbocharged car is not accurate as someone else has mentioned. Based on that other correction factor I see you're likely making 255 whp.
With that said every dyno is different. On the a relatively low reading dynajet I had a customer with 290 whp pump gas hit 110 (stock turbo sti, Hydra EMS,TBE, FMIC) and my car went 112 mph with 309 whp pump gas (same mods). Other dynos in our area need 335-340 whp to hit 110-112 mph.
Now you know so adjust your HP goals to get the trap speeds you want.
Element Tuning is offline   Reply With Quote
Old 10-05-2012, 12:01 PM   #47
ScoobyDoo69er
Member#: 82965
My contribution.
284whp 2003 Blobeye STi Type UK - So the 2.0litre model.
12.1 @ 113mph
Graph and video:
https://www.youtube.com/watch?v=UliHkXPZ24E
ScoobyDoo69er is offline   Reply With Quote
