Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-01-2012, 02:53 PM   #1
robking18
Member#: 330574
Default 05 Impreza rs w/ STI cluster help!!!
I have an 05 Impreza RS and recently found a STI cluster for an undisclosed price that I could not pass up. I installed it and thought, wow, fairly easy. Abs light and cel on but i can manage that. I noticed my running lights were on even though the light switch was in the off position, and the keys were not even in the ignition. I had to remove the 20 amp fuse for the lights in order to prolong my already straining battery. Any ideas or help would be appreciated. Also, the factory alarm upon hitting lock and closing my door no longer flashes my lights or beeps while the 20 amp light fuse is in. When its out, and the running lights are no longer on, the "armed" beep and flash work. Im stumped. The brake lights still work with the fuse out so i might just run a switch for when it gets dark until i can figure this out. PLEASE help.
robking18 is offline   Reply With Quote
Old 10-01-2012, 03:19 PM   #2
robking18
Member#: 330574
hopefully its just the switch on top of the column....if it is ill /facepalm
Old 10-01-2012, 06:30 PM   #3
robking18
Member#: 330574
Annnddd it was the button. I almost walked into a wall on purpose afterwards.
