Old 09-30-2007, 10:42 PM   #1
Spec V to Wagon
Member#: 129715
03 Wagon
Default HOW TO: (w/ pics) STI cams in WRX heads
I searched and didn't find to much so I'm writing something up myself. My motor took a dump so I'm doing a 2.5 hybrid and I'm using STi cams. As you know STI cams can be used but the AVCS plugs need to filled. You can either weld them or plug them. I decided to plug them.
First you'll need some supplies
1. Eight (8) 5mmx5mm .8thread set screws
2. 5mm x.8 pictch tap
3. Red loctite
4. STi cams
5. Some grease
6. File
7. Carb cleaner
8. 2.5mm allen key
Step one.
Put some grease on the tap and run it down into each hole on the front side of the cam (4 on each cam.) Only the intake cams have these holes. Make sure that after each turn or so you back the tap out to clean off the filings.
Step two.
Make sure that all your holes are deep enough. The set screws want to be just below the surface of the cam. If they are deep enough you want to take the file and clean the face of the cam as when you tap it you'll pull material to the surface. Be carefull to not file the face of the cam to much.
Step three
Take the carb cleaner and clean all the holes with carb cleaner really well and make sure they are dry.
Step four.
Apply red loctite to the the threads of the set screws and screw them into the cam. Seat them just below the surface of the cam face.
Step five.
Enjoy.
Spec V to Wagon is offline   Reply With Quote
Old 09-30-2007, 11:14 PM   #2
wrxhard
Member#: 108091
Ummmm... Carb cleaner usually leaves a light oily residue, i HIGHLY recommend using brake cleaner. The oily residue will affect how and if the loctite sets up.
wrxhard is offline   Reply With Quote
Old 09-30-2007, 11:17 PM   #3
S L O W W R X
Member#: 95109
Nice writeup thanks
S L O W W R X is offline   Reply With Quote
Old 09-30-2007, 11:29 PM   #4
Spec V to Wagon
Member#: 129715
03 Wagon
They set up very quickly. My turner told me to use carb cleaner so I did. But good advice to look out for.
Old 10-01-2007, 06:47 PM   #5
Bombay994
Member#: 108898
2004 wrx
hybrid stg3..hang on 5MT
I'm a few days away from my motor tear down and will be doing the same 2.5 hybrid with the STI cam swap....greatly appreciate this post...huge help!
Bombay994 is offline   Reply With Quote
Old 10-01-2007, 06:59 PM   #6
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
glad to see the cams worked out well for you jeff. Order buckets yet?
turboL is offline   Reply With Quote
Old 11-19-2007, 03:06 PM   #7
WJM
Guest
Member#:
Nice.
Old 02-09-2008, 08:37 PM   #8
Paulys05wrx
Member#: 82433
2005 In the works..
Thanks to Spec V for the write up... I followed it pretty much to the T. I had a few problems; The M5 tap I was using was a bit large in diameter and I had a hard time getting it in. My solution was to drill out the holes just a bit until my tap fit. My suggestion to anyone else who is doing this is to use a 8/32 tap which fits perfect but I do not know if you can find 8/32 set screws so I stuck with the above parts. Anyways just throwing my two sense in and here are a few pics of my finished product.
Paulys05wrx is offline   Reply With Quote
Old 02-11-2008, 11:49 AM   #9
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
nice job on the write up..
Old 02-11-2008, 04:16 PM   #10
wrx2k4
Member#: 68632
2004 wrx/xtra hybrid
psm
+1 good stuff!
wrx2k4 is offline   Reply With Quote
Old 02-12-2008, 10:10 AM   #11
8Complex
Member#: 922
04 FXT
Red
FWIW, the tap drill diameter for a M5x0.8 thread should be 4.2 (0.165"). If you drill those holes up to that size before tapping, everything should go smoothly.
Rule of thumb for metric threads, tap drill = thread diameter minus pitch (5 - 0.8 = 4.2).
8Complex is offline   Reply With Quote
Old 02-16-2008, 07:06 PM   #12
02wrximpreza
Member#: 151601
2002 WRX-Cobb Stage2
Would it be worth while doing the cam swap in a WRX? Using WRX block and head?
If so what would the pros and cons be anyone know?
02wrximpreza is offline   Reply With Quote
Old 02-16-2008, 07:37 PM   #13
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Why isn't this thread a sticky?
LiquidForce is offline   Reply With Quote
Old 02-18-2008, 12:39 PM   #14
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Please make this a sticky...
Ralliart4 is offline   Reply With Quote
Old 02-20-2008, 04:41 PM   #15
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Im getting ready to throw sti cams in my wrx heads and finish up my hybrid build..My question is are you guys still using stock wrx valvetrain with the sti cams? Im looking to do the same but am on a budget so im trying to see what my options are and whats in my best interest..Thanks
wrxwagon253 is offline   Reply With Quote
Old 02-20-2008, 05:56 PM   #16
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
As the only difference in the STI cams and the WRX cams is the lift, you will be able to reuse the WRX valvetrain. I suggest you take the heads to a machine shop to be refurbished and have the lash set though. It's well worth the money.
paintbing is offline   Reply With Quote
Old 02-20-2008, 09:22 PM   #17
Paulys05wrx
Member#: 82433
2005 In the works..
Yes you may use the WRX valvetrain with no problems. Just check and re-check the valve lash and everything should be good! Good luck. Mine are on my motor now and it is getting put back in this weekend.
Old 02-20-2008, 09:33 PM   #18
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
Awesome stuff man!
shameless plug, but I have a set of stock USDM 04 STi cams for sale.
AdamBOMB_STi is offline   Reply With Quote
Old 02-22-2008, 01:24 PM   #19
Paulys05wrx
Member#: 82433
2005 In the works..
Okay, I have everything in and ready to be started shortly. I am very very scared and concerned that the plugs I put in might leak. I have no reason to be concerned as i did the mod correctly it's just my human nature to worry I guess. Lets just say somehow a little bit of oil gets through those plugs, whats the worst case scenario? Oil leak from the cam seals area? Any comments are welcome to help calm my nerves.
Old 02-22-2008, 02:20 PM   #20
Spec V to Wagon
Member#: 129715
03 Wagon
I forgot about this thread and I was going through my photobucket account and saw the pictures were still hosted.
glad I could be a service!
As answered just doing the STI swap into a stock block and head wrx isn't worth the trouble. Though the stock valve train can be used cause the STI cams only have a higher lift.
Old 02-25-2008, 09:23 PM   #21
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
doing mine now jeff. but wtf, tapping these holes is a bitch. My hands are raw, the tool is stripped (not the tap but the tap holder)...and I am only done two.
Old 02-26-2008, 02:34 AM   #22
wrxwagon253
Member#: 125620
05 3076R Wagon
Is there a easier way of plugging the holes that anyone knows of?
Old 02-26-2008, 11:21 AM   #23
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
JB weld.
Old 02-26-2008, 05:18 PM   #24
Spec V to Wagon
Member#: 129715
03 Wagon
Make sure you use grease and back the tap completly out after like one full turn. The **** that grinds off will bind the hell out of the tap and make it very hard to keep going.
Like posted above, drilling the holes a little bigger will also work, though I don't know what size bit to use.
Old 02-26-2008, 06:55 PM   #25
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
i drilled it...and then it was easier than pie.
How To: Install Evo X seats in wrx/STi xxscaxx Interior & Exterior Modification 167 03-09-2012 11:15 PM
sti cams in 2L heads wickedwrx2002 Factory 2.0L Turbo Powertrain 2 12-03-2007 05:43 PM
sti cams in wrx heads? ejsportcom Built Motor Discussion 22 06-22-2006 03:34 PM
do sti cams in wrx heads really make that much of a difference? legacy2003 Factory 2.0L Turbo Powertrain 5 01-15-2006 01:31 PM
STI cams in WRX heads=cel??? Davenow Subaru Conversions 0 03-28-2005 01:59 PM
Message Board Statistics All times are GMT -4. The time now is 03:55 PM.
