Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 10-01-2012, 06:23 PM   #1
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Default Dyno Tune: Cobb Plano + 03 WRX + NEW Forced Performance HTA71 makes 426 WHP/417 WTQ
Event: dyno pull
Ambient Temp: 95 degrees
Elevation: Unknown
Weather: Sunnny & Humid
Car: 2003 Sonic Yellow WRX
Tuner: Calvin Dotson - Cobb Tuning
Dyno Info: Mustang
Transmission: 5spd ppg gearset
Gear: 3rd
Peak HP at RPM: 426 HP @ 6000 (uncorrected)
Peak Torque at RPM: 417 @ 4000 (uncorrected)
Baseline hp/tq for a stock on same dyno:
Target Boost: 23 psi
Target AFR: 11.7
Fuel: E85
Engine/Power Modifications: Watt's Shop Built 2.5L, CP Pistons (9.2:1 CR), Pauter Rods, 2.0L Heads, EQ Tuning CNC Chambers, 2006 STi Camshafts, BC valvesprings, Forced Performance HTA71 with advanced flow port, Internal Wastegate, FP 84mm turbo inlet, ETS Top-Mount Intercooler, KS Tech Intake, Invidia Catless DP, GT Spec UEL Header, ID 1000 injectors, DW 300lph in-tank.
Driveline Modifications: PPG 5-Speed, OBX Front Diff, Kartboy shifter and bushings, Group N Engine/Trans Mounts, Positive Shift Kit, Diff lock bolts.
Suspension Modifications: BC Coilovers with custom valving and spring rates, Cobb Sway Bars, TIC Enthusiast Control arm bushings, Whiteline Positive Steering Response Kit, Vorshlag Camber Plates, STi Control arms and lower rear links, Front and Rear strut mounts, under car cross-bracing.
Other Modifications: STi Steering Rack.
Squidz is offline   Reply With Quote
Old 10-01-2012, 07:28 PM   #2
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
How did this turbo respond? Well, in your opinion and the tuners? Its looking good so far
wrxsubiemod is offline   Reply With Quote
Old 10-01-2012, 08:53 PM   #3
Squidz
Member#: 142608
2003 Sonic Yellow
Both me and my tuner were both very impressed with the response of this turbo. We actually ran out of injector...at 26-27 psi, this turbo should make 470-490 WHP.
It actually spoools very fast for the power that it makes.
Old 10-01-2012, 08:58 PM   #4
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Hardwire and FPR with more base pressure?
Zee Biker is offline   Reply With Quote
Old 10-01-2012, 09:18 PM   #5
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Thank you
Old 10-01-2012, 11:36 PM   #6
ArSoN9
Member#: 285777
2004 STi-
very impressive torque curve with internal wastegate
id like to see some engine bay shots of ur setup!
ArSoN9 is offline   Reply With Quote
Old 10-02-2012, 01:53 PM   #7
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
I'd say it spools damn fast for the what its making. Good job!
JoeTX is offline   Reply With Quote
Old 10-02-2012, 02:57 PM   #8
Squidz
Member#: 142608
2003 Sonic Yellow
Probably...down the road. Didn't really want to have to put aftermarket fuel rails on it...looks really clean this way. I'm really happy with it right now...and as an autocross car, it makes more than enough power.
Now i just have to re-learn how to drive it with 100 more WHP.
Old 10-02-2012, 10:40 PM   #9
sonic_wrx189
Member#: 207905
2003 subaru wrx
sonic yellow
How is running higher comp pistons? I'm in the process of building a 2.1 stroker and am advised to stay away from higher compression because it's mote knock prone.
sonic_wrx189 is offline   Reply With Quote
Old 10-02-2012, 10:54 PM   #10
Squidz
Member#: 142608
2003 Sonic Yellow
Havn't had any issues. The off-boost response is excellent and the engine takes boost like a champ. Tuner did not have any knock issues when tuning the car. he actually wished we had had a bigger injector or more fuel pressure to turn the boost up.
Old 10-03-2012, 02:11 AM   #11
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
E85 has tons of margin in it at stock CR. You sure will see these issues with a 0.5-1 point CR bump on pump gas, but on E85? Shouldn't see knock with such a small bump in compression.
Concillian is offline   Reply With Quote
Old 10-03-2012, 08:36 AM   #12
CatfaceType-R
Member#: 81102
Pretty interesting, shawn. How does she spool on the street?
No avcs, right?
Carmi (new sn)
CatfaceType-R is offline   Reply With Quote
Old 10-03-2012, 02:59 PM   #13
tja1618
Member#: 181995
2003 WRX
Pretty excited to see this seeing as I have a 71HTA on order my self. Although I'm putting mine on a stock 2.0L in a 2003 WRX. I'll be running pump gas as well, so I'm not expecting these kind of numbers. Either way that's pretty impressive.
Have you seen this turbo on a 2.0L? I wonder how much different it will spool...I'm getting my stock manifold ported with a new crosspipe and EWG.
tja1618 is offline   Reply With Quote
Old 10-04-2012, 07:34 AM   #14
Squidz
Member#: 142608
2003 Sonic Yellow
No avcs, right?
Carmi (new sn)
It spools great...only thing i wish is that it was a little more linear...but for the power it's making, it's very impressive on the spool side of things. Can't believe that this thing is capable of easily 50 WHP more. Turbo was actually designed to run 26-27 psi. The engine increased off-boost response significantly, and the turbo is making a bar of boost by 3500...so the car feels plenty quick down low.
No, no AVCS, which i'm regretting just a little bit with this build. I think the power would have come on a lot smoother and a bit sooner with it.
Havn't seen this turbo on anything. Mine is the first Suby to have one.
I would personally think this turbo really needs E85 to perform the way it was designed. As stated above, it was originally developed for use in higher boost applications.
Old 10-04-2012, 09:13 AM   #15
JGLew82
Member#: 290413
Impressive! Nice job man. Wouldn't mind checkin it out sometime.
JGLew82 is offline   Reply With Quote
Old 10-04-2012, 09:20 AM   #16
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Nice too see some results. Thing seems to be a beast. Also has nice spool.
rexworx is online now   Reply With Quote
