Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Old 10-09-2012, 03:18 PM   #1
subbyboer
Member#: 316561
Default Dam Dropping Below 16????
My car has been running fine and I have kept an eye on everything and I haven't heard any knocking noises other than my forged pistons being load. But this afternoon when I drop my car , I check my DYNAMIC ADVANCE MULTIPLIER AND IT AT 15. Can someone please give me some place where I can start to look. Or any ideas on what might be the problem
subbyboer is offline   Reply With Quote
Old 10-09-2012, 09:42 PM   #2
rotheee
Member#: 291964
2003 WRX
mine is also at 15, currently in limp mode since my car is tuned to go into limp anything below 16.
rotheee is offline   Reply With Quote
Old 10-09-2012, 11:39 PM   #3
zashoe
Member#: 329523
2002 Impreza WRX
World Rally Blue
mine is currently at 13. anyone know what's causing everyone's numbers to drop?
Edit: I AM, unfortunately, experiencing fine knock learning. So any ideas would be greratly appreciated!
zashoe is offline   Reply With Quote
Old 10-10-2012, 12:47 AM   #4
zashoe
Member#: 329523
2002 Impreza WRX
World Rally Blue
are either of you running launch control? I was, and it disabled BCS and sped up timing which made me swing lean and knock under high load. hopefully your solutions are as simple. good luck fellas.
Old 10-10-2012, 03:17 PM   #5
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
This can also change based on the fuel. Its starting to get cold outside and many pleases will switch to E10 fuel for winter months.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 10-10-2012, 03:45 PM   #6
art@grimmspeed
Member#: 301037
2004 Forester XT
Normally when the multiplier drops it means that the ECU is seeing knock in a large area. Which could be caused by bad or low octane gas or could be due to a bad or incomplete tune. What tuning software are you using? Do you have learning view?
art@grimmspeed is offline   Reply With Quote
