Old 09-21-2011, 06:01 PM   #1
xshaggy4
Member#: 289670
2010 impreza
metalic grey
Default headers for Avo turbo kit
I have a 2010 subaru impreza and installed a Avo turbo kit but I want to know if there is a bearded that works with the Avo turbo kit
xshaggy4 is offline   Reply With Quote
Old 09-21-2011, 09:27 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Is this an OEM location turbo?
Old 09-21-2011, 09:35 PM   #3
xshaggy4
Member#: 289670
2010 impreza
metalic grey
This location is on the back of the engine on top next to the firewall, by the abs module
Old 09-23-2011, 09:41 AM   #4
GEE-OTTO
Member#: 201277
2008 Legacy
YES it is OEM liek location except it is rotated as the EJ253 doesnt have a maifold that a Ej255 inlet would clear. There are no headers for the EJ253 therefore there are NO headers for this kits. Paul and AVO built the kit around the stock EJ253 manifold they have a header in the works , I know because i sent them the mock up, but it doesnt have a date for completion at this time.
This issue goes hand in hand with the EJ253 crying for headers which they won't buy due to price SO the only option would be to have a header built using stock locations (mid pipe flange and oil pan clearances as references)
Couple flanges and few feet of 304 or 321 and he'll be set
GEE-OTTO is offline   Reply With Quote
Old 09-23-2011, 09:51 AM   #5
GEE-OTTO
Member#: 201277
2008 Legacy
This is a 2009 Legacy 2.5i with the AVO 2.5i turbo kit installed. and here is the UP notice the stock manifold:
So you make a EJ253 header using stock locations to jump this short hurdle
Old 09-23-2011, 12:21 PM   #6
tablesandchairs
Member#: 294641
Wow that is nuts!
tablesandchairs is offline   Reply With Quote
Old 09-23-2011, 10:35 PM   #7
xshaggy4
Member#: 289670
2010 impreza
metalic grey
Dam that's what Paul frm Avo turbo world told me too. But hey thanks ill probly build my own hearders
Old 09-23-2011, 10:37 PM   #8
xshaggy4
Member#: 289670
2010 impreza
metalic grey
My engine is the EJ25
Old 09-24-2011, 12:25 AM   #9
GEE-OTTO
Member#: 201277
2008 Legacy
Yes the EJ series 2.5L concept hence EJ25 the variants withing the EJ25 family are as follow EJ25D, EJ251, EJ252, EJ253, EJ254, EJ255, EJ257
ALL non turbo H4 Subarus 06+ have a EJ253 installed from the factory with the exception of the 11 forester (it has a EJ253 phase 3) and the NEW 12' Impreza which has a FB20 engine.
The layout of your IMpreza and the Legacy are nearly identical which is why the kit can be installed on either without worry. The slight difference being clearance near the firewall for the IC piping going into the TB.
Old 09-24-2011, 12:39 AM   #10
xshaggy4
Member#: 289670
2010 impreza
metalic grey
Yea did you have problems installing your kit on your legacy
Old 09-24-2011, 12:51 AM   #11
xshaggy4
Member#: 289670
2010 impreza
metalic grey
Which one of those blocks would be good to handle boost?
Old 09-24-2011, 11:59 PM   #12
GEE-OTTO
Member#: 201277
2008 Legacy
Well you have a EJ253 the engine can handle boost but not 12PSI reliably maybe 8-9 psi max but more like 6-7 psi over the long haul.
Of the engine codes i listed you only need to worry EJ253, EJ255 and EJ257 of those you only need to worry about EJ253 b/c that is the engine in your car from the factory.
OF the engines that best handle boost well that would be the EJ255/7 b/c that is what they are designed for. If you are thinking of getting a EJ255 and rebuilding it for this kit SAVE YOUR MONEY as that would be a waste of money since these engines can handle triple the output of the AVO kit.
Old 09-25-2011, 12:44 AM   #13
xshaggy4
Member#: 289670
2010 impreza
metalic grey
Thanks man you've been helpful all the times . I was Jst curious which subaru engine was able to handle boost, but how much boost can the EJ255 block handle
Old 09-27-2011, 10:56 PM   #14
Swagon_Wagon
Member#: 294424
1998 Impreza STI RA
the Ej25d is cheap and boostable, just gotta lower the CR, people have ran 17 on it....
Swagon_Wagon is offline   Reply With Quote
Old 09-27-2011, 11:17 PM   #15
xshaggy4
Member#: 289670
2010 impreza
metalic grey
What's the difference between the EJ25 and the EJ25d
Old 09-28-2011, 10:36 AM   #16
GEE-OTTO
Member#: 201277
2008 Legacy
The EJ25 is a family of engines (EJ25D, EJ251, Ej253...Ej257 being the top)
EJ25d is a phase 1 Subaru engine. However there was a Ej25d revision between 96-97 and 97-98.
Old 09-30-2011, 12:23 PM   #17
c0nn0rwils0n
Member#: 262203
2009 Impreza 2.5i
what kind of gains did you experience from putting in the avo turbo kit? i was thinking of doing the same but wondering if it was worth it.
c0nn0rwils0n is offline   Reply With Quote
Old 09-30-2011, 07:10 PM   #18
xshaggy4
Member#: 289670
2010 impreza
metalic grey
You do gain a lot of power you gain 100hp
Old 10-03-2011, 01:25 PM   #19
GEE-OTTO
Member#: 201277
2008 Legacy
Reliable 200 awhp and torque with room for gains
Old 10-14-2012, 02:33 AM   #20
SlicksubieSD
Member#: 324407
so let me get this understood ... the AVO 2.5i turbo kit can work on the FB20 in the impreza's?
SlicksubieSD is offline   Reply With Quote
Need Install for AVO turbo kit in/near Michigan Rallitek.com Mid West Subaru Owners Club Forum -- MWSOC 4 09-19-2006 05:59 PM
Latest Map for AVO Turbo Kit w/ Link ECU Rallitek.com Normally Aspirated with bolt-on Forced Induction Powertrain 20 04-08-2005 03:22 AM
AVO Turbo Kit vs TSI Turbo Kit Mechkiller31st Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-01-2004 07:02 PM
This is what you've been waiting for! AVO Turbo Kits! Rallitek.com Vendor 'Group Buy' Classifieds 33 11-22-2004 11:30 AM
Header for Ludespeed turbo kit? Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 40 10-16-2002 03:36 AM
Message Board Statistics All times are GMT -4. The time now is 03:09 AM.
