Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 07-09-2013, 06:59 PM   #1
CriticalityEvent
Member#: 281670
2012 WRX
Default Hood deflector compatibility
Hi all,
I’m looking to minimize the number of holes being punched into the paint on the front of my hood (moving forward, at least). I have a '12 WRX. The only deflector that I’ve been able to find has been this one:
http://www.subaruwrxparts.com/shop/p...ry=266#details
That site categorizes that deflector under “2008-13 WRX/Sti/2.5i.” Are front of the hoods for all three models across all of those years identical? I’m given more pause when I saw that same part here:
http://www.subarugenuineparts.com/pr...oducts_id=1280
That site states “not for turbo models,” but I’m wondering if that’s due to concerns that I’ve seen in various threads regarding the deflection of air into the scoop.
Ugh… I should’ve gone with a clear bra from the get-go.
Thanks!
CriticalityEvent is offline   Reply With Quote
Old 07-09-2013, 07:14 PM   #2
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Subaru doesn't recommend the deflector for the WRX/STi because it pushes air away from the scoop, reducing its effectiveness at cooling the intercooler. I don't know how much of a difference this actually makes in practice, though.
That being said: you can probably install the non-turbo model deflector on a WRX/STi just fine, because the leading edge of the hood is the same. xluben had a non-scoop hood installed on his WRX after he put a FMIC on the car - there are no shape differences around the edges.
evilspoons is offline   Reply With Quote
Old 07-10-2013, 12:09 AM   #3
sc00by4life
Member#: 97135
Just do a clear bra.
Old 07-10-2013, 09:25 AM   #4
Tfivem
Member#: 357454
2013 WRX Limited GR
2015 Impreza Hatch CWS
someone on here went through the trouble of actually mounting one on his WRX, and recording before and after flow lines to see if it actually harmed airflow to the intercooler, which it did not,
ill try and find the link
EDIT* Found it:
http://forums.nasioc.com/forums/show....php?t=2405189
Tfivem is offline   Reply With Quote
Old 07-10-2013, 09:47 AM   #5
tilegend
Member#: 295565
I had one installed for a few months now. Haven't done any quantifiable tests but yeah from that thread you can pretty much see the height of the deflector vs the hood scoop.
tilegend is offline   Reply With Quote
Old 07-10-2013, 04:04 PM   #6
CriticalityEvent
Member#: 281670
2012 WRX
I should’ve done this as soon as I got the car, but none of my previous cars seemed to attract rock chips to the degree that the WRX does on that part of the hood. My other cars’ hoods must have had a very different angle on their leading edges. Now, I need to grind some small rust spots that have started forming and touch it up before thinking about the clear bra, but I have a trip next weekend and the deflector is now the only option I have.
EDIT* Found it:
Yep, that’s the thread that I was thinking about. I thought all those pictures’ links were broken, turns out they were just blocked by my company’s network. >:-/ That video link IS broken, however. From what I read, I would agree with you that there is probably nothing to worry about from that perspective.
Thanks everyone!
Old 07-10-2013, 06:21 PM   #7
garudatwo
Member#: 322385
I've been using it on mine for a while, seems to help with the rock chips (i.e. haven't seen any new ones since install):
garudatwo is offline   Reply With Quote
Old 07-11-2013, 11:47 AM   #8
CriticalityEvent
Member#: 281670
2012 WRX
That car is SHARP. If I knew how good silver (SSM?) would look with the accents created by material that is also meant to protect the car, I would've gone with that instead of DGM.
Just to update: I ordered the deflector online, but tried getting it from a local dealership first. The guy in the parts department immediately voiced his concern regarding airflow, and then went on to say that using this would "void the warranty on the turbo." Since the intercooler is after the turbo, wouldn't the deflector cause more damage to the engine (theoretically)?
Old 07-30-2013, 01:41 PM   #9
WilR
Member#: 343078
2013 WRX Hatchback
I think that is a pretty ridiculous claim from the dealership, none the less he will probably be the idiot that is on the clock should you have to bring it in for something.
With that being said, I plan on ordering one myself because I cannot stand the paint chips . Did you order from the links above? How was the fitment?
WilR is offline   Reply With Quote
Old 07-30-2013, 03:45 PM   #10
btc2112
Member#: 322981
2012 WRX 5 Door
Complete and total bs. Was this a tech? Oh man... I'd immediately thank him for his time and never, ever, ever bring my car in to be serviced there.
btc2112 is offline   Reply With Quote
Old 07-30-2013, 04:36 PM   #11
sc00by4life
Member#: 97135
It's possible that a modification that adversely effects the motors operation would be subject to scrutiny.
While it may not VOID the warranty, you could definitely face a denial of service.
Use some common sense.
Old 07-31-2013, 06:46 PM   #12
CriticalityEvent
Member#: 281670
2012 WRX
Yep, ordered it from this link:
It came pretty fast and exactly as described. Here is a picture:
Just FYI, throw a blanket or tarp over the engine bay; I had a couple of close calls when a screw fell out of my hand as I was threading in a bracket.
I don’t think it was a tech; I asked to speak to speak to someone in the parts department. I’ve actually gone out of my way to take my car to this dealership before because their techs are that great (Liberty Subaru in Illinois).
I understand that it might it might cause damage to other parts of the engine, but the guy I spoke to in the parts department was very specific about the deflector damaging the turbo itself. What do you mean by “use some common sense”?
Old 07-31-2013, 06:55 PM   #13
btc2112
Member#: 322981
2012 WRX 5 Door
Common sense?
Sure-
Our warranties cannot be voided. Period. Any tech or wrench turner who tells a customer otherwise can pound sand. No one said anything about scrutiny if I recall correctly...
Reading AND comprehension- if you're only gonna do one of them, might as well forget the other...
Old 07-31-2013, 06:57 PM   #14
btc2112
Member#: 322981
2012 WRX 5 Door
He was speaking to me about common sense...while not exercising a whole lot of it himself...
Pot meet kettle Aaaannnd welcome to NASIOC!
Old 07-31-2013, 07:08 PM   #15
sc00by4life
Member#: 97135
Common sense?
Sure-
Wrong. There are a couple of scenarios where an entire warranty can be void by SOA. This wouldn't be one of them, but there ARE things that will cause SOA to completely void a warranty.
You said a warranty cannot be void, but it can. And I was also pointing out, that it is very possible that you can risk service denial due to a hood deflector that is specifically stated NOT FOR TURBO MODELS as it can and will divert air around the scoop - causing the motor to run excessively hot and potentially cause damage. You might want to work on that comprehension part.
Old 07-31-2013, 08:33 PM   #16
btc2112
Member#: 322981
2012 WRX 5 Door
Oh jesus... In this case his warranty cannot be voided. Service denied? Hell yes! But that's not what I said.
Can you describe said scenario where a warranty is VOIDED by installing a deflector? Or by installing ANY aftermarket parts? You keep saying service denial; yeah we already know that's possible, it wasn't the issue guy.
Damn man, you're like the old senile grandpa who just keeps repeating the same redundant crap over and over. Technically you're right but what you're saying has ZERO bearing here. We get it, you know a lot and you help out us newbs but you're so quick to try to poke holes in someones statement, you miss what's really being said.
Reading AND comprehension boss, you're still not getting it..
Old 07-31-2013, 09:23 PM   #17
sc00by4life
Member#: 97135
You said a warranty can not be voided. Period. Which is wrong.
That isn't the question. If you want to keep talking about "reading comprehension", you might want to try it for yourself.
Actually, it IS the issue. OP is concerned with warranty coverage after the tech mis-spoke and said the turbo warranty would be void. This is untrue, but the deflector CAN cause service denial - which is the exact thing OP is concerned about. Reading, its hard, i know.
Read the third sentence of the post you quoted. Service denial is 100% what we are talking about, I was merely making the distinction between VOID and DENIAL.
Again, reading is hard. I'm providing clarification in the mess that this thread has become (you know, with you trying to e-flex).
I'm not poking holes in anyones statement. I was correcting what the tech said versus what he meant. I posted it several times already, though I'm sure you didn't even bother reading what I posted.
300k+ AND SCIC. Not surprised.
Old 08-01-2013, 08:47 AM   #18
btc2112
Member#: 322981
2012 WRX 5 Door
We know what the tech said vs what he meant bud... That's what I pointed out before you wanted to chime in about common sense.
You seem to be stuck on that though. Yes service denial but not voided warranty.
We get it pops, you were a big deal back in your day...
Old 08-01-2013, 02:35 PM   #19
sc00by4life
Member#: 97135
you really are that stupid.
Old 08-01-2013, 05:55 PM   #20
CriticalityEvent
Member#: 281670
2012 WRX
Uh… thanks for the input guys. I guess I’ll be removing the deflector this weekend because my car threw misfire codes for all four cylinders so I had better take it in. Not the first time; it had a misfire on cylinder 1 a couple of months back.
