Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 09-11-2012, 02:00 PM   #1
Thermo
Member#: 317109
Default 2012 Impreza 2.0i Handbrake Poll
Just a quick question for all the Impreza 2.0i owners.
If you could perform a quick test: Drive the vehicle at any speed, 5 mph (in a parking lot) is sufficient, and pull and release the handbrake (keep the button on the lever depressed). It doesn't have to be pulled very strongly. Do you hear a bang or thud when the brake is engaged?
I haven't taken the rear brakes apart to look at them yet, since the car is brand new and under warranty, but the dealer is telling me that this is normal and all Impreza 2.0i's do this.
Thanks.
Thermo is offline   Reply With Quote
Old 09-11-2012, 02:24 PM   #2
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
You shouldn't be pulling the handbrake while the car is in motion unless it is an emergency.
That being said, when I have pulled it on my WRX and not been at a complete stop there is a sound from the rear end.
CopperTopNWOR is offline   Reply With Quote
Old 09-11-2012, 03:18 PM   #3
Thermo
Member#: 317109
From a technical standpoint, I disagree. Barring any sort of extreme handbrake engagement, there is no detrimental effect to the braking system or drivetrain by applying the handbrake while in motion.
I would agree that there is no point to doing it (unless you are testing, performing maintenance, or like you said, in an emergency), since the braking effect is very low compared with the vehicle's main braking system. In fact, the owner's manual states that the handbrake should be engaged at approx. 22 mph to break-in the brake shoes.
In my WRX, there is no sound when the handbrake is engaged while the vehicle is moving. In any case, thanks for your response. I'm trying to determine a trend here, so if a significant proportion of Impreza's do this, then it may just be a benign effect of the system's design.
Old 09-12-2012, 02:50 PM   #4
Geethirtyfour
Member#: 331031
I get a squeal on my WRX when I pull hard, like the pads are worn down to the wear sensors which can't be true. I did the break in and I have only 500 miles on the car. No bang or thud, sorry.
Geethirtyfour is offline   Reply With Quote
Old 09-14-2012, 09:39 AM   #5
Thermo
Member#: 317109
Thanks Geethirtyfour. It's starting to look like most of the Subaru's with this setup have some sort of clunking. I still have to take a look at it this weekend, but it looks like a rather basic setup with rather low tolerances, so things shift about somewhat.
Old 09-21-2012, 10:02 PM   #6
RememberMeJoeB
Member#: 332926
2012 Imp
yea i did that by accident terrible noises ensued and it scared me enough to never do it again. I used to be able to spin the spec-v with the handbrake i miss my spec-v.
RememberMeJoeB is offline   Reply With Quote
Old 09-30-2012, 06:01 PM   #7
ans2k
Member#: 315631
2012 Impreza Sport
yea, i hear it in my 2012 sport imp
Old 09-30-2012, 06:55 PM   #8
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Elaborate please.
RoadKillDMD is offline   Reply With Quote
Old 09-30-2012, 10:39 PM   #9
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
He's getting at the fact that it's fine to slow down with the e-brake if you're not locking up the rear tires (partial engagement, if full engagement is the e-brake fully yanked while parked), although you won't be able to stop for **** at any kind of speed using just the e-brake.
I have done this to stop my car from rolling down a hill without the engine on and I have never heard any such thud.
chazly413 is online now   Reply With Quote
Old 10-01-2012, 09:04 AM   #10
Thermo
Member#: 317109
Originally Posted by RoadKillDMD View Post
Elaborate please.
The proper way to go about this is to ask how it would damage the vehicle, and you'll find that you won't have an answer.
If you're looking for the short and sweet answer, then chazly had it.
Old 10-01-2012, 11:44 AM   #11
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
You must realize that this means to engage as in to begin to grab and not an all-out full-engagement to lock. These are two different types of 'engagement'.
To clarify (per Thermo below), I did read this post. I chose this sentence to emphasize because at its face, some may not understand that there is a fundamental difference between "extreme handbrake engagement" and "the handbrake should be engaged"; extreme versus non-extreme engagement (or to lock), which is not the case.
Old 10-02-2012, 04:15 PM   #12
Thermo
Member#: 317109
I think you need to re-read the post (as well as the other posts) and you'll see that we already covered that fact. Even the statement you quoted in your post contains this information: "Barring any sort of extreme handbrake engagement, there is no detrimental ..." (second sentence).
However, in restating what has been stated, you are correct nonetheless.
Also, I would argue that, if you are trying to break-in the shoe lining, then you would prefer moderate engagement over light ("begin-to-grab") engagement. Of course light/moderate/heavy/severe/etc. are all terms that are subject to interpretation. :-)
