Old 10-02-2012, 02:16 PM   #1
trevorm3
Member#: 291879
02 Bugeye
Default Need help removing cel and speed limiter
Hi all! I'm pretty new to open source tuning and I have a few questions.
I perchest a new tactrix 2.0 cable and want to start learning. I have an 02 wrx
With a V8 swap. I really want to get rid of the speed limiter on the v8 ecu. It cuts out at about 190kph(118mph) I also want to delete the rear O2 sensor.
The CEL came on the other day and the sensor is no good. I have looked on here and goole for some straight answer on how to do that with the tactrix cable but
No success.
I have all the programs downloaded that are needed to flash
My ecu.
trevorm3 is offline   Reply With Quote
Old 10-02-2012, 03:20 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Open ECUFlash, download the current ROM, open it, turn off the CELs, save it, flash it back to the ECU.
Is there anything specific you have a question about? The process is very straight forward.
Old 10-02-2012, 03:22 PM   #3
KleenREX408
Member#: 333899
2005 WRX Sedan
Someone correct me if I'm wrong. As I'm also new to tuning.
But if you open your .hex file in RomRaider, You can expand the Diagnostic Trouble Codes folder and inside there is all CEL's. Just highlight and disable.
As for the speed limiter, its just under the limiter folder > Speed Limiter.
KleenREX408 is offline   Reply With Quote
Old 10-03-2012, 07:42 AM   #4
trevorm3
Member#: 291879
02 Bugeye
I want to delete the rear O2 sensor completely, not just turn the light off.
Old 10-03-2012, 08:17 AM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Why? It does more good having it there than not.
Black94Snake is offline   Reply With Quote
Old 10-03-2012, 11:46 AM   #6
trevorm3
Member#: 291879
02 Bugeye
Well everyone keeps telling me that when I have my car tuned there just going to delete it anyways. I have read up on it and I get mixed results. People say it does nothing and others say it does.
Old 10-03-2012, 12:03 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
In newer cars like mine, you still use it for A/F adjustments. Yours might not though.
Old 10-03-2012, 12:34 PM   #8
trevorm3
Member#: 291879
02 Bugeye
Well if that is the case I will buy a new o2 sensor and clear the light.
