Old 10-02-2012, 04:23 PM   #1
SubieNut09
Member#: 226080
05 Impreza
Default Spark Plugs
Hi, I have an 09 Impreza 2.5 non turbo coming up on 31,000miles and want to replace my spark plugs, I was thinking of going with the NGK Iridium, or the Bosch Iridium, are these ok to use or should I just use the stock plugs? I figure I could get more mileage on these plugs. Which one do you recommend and do I need to use anti-seize.
Thanks in advance.
Bob.
SubieNut09 is offline   Reply With Quote
Old 10-02-2012, 04:40 PM   #2
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
I believe NGK is the OEM brand so they are a good choice and skip the anti-sieze as it is not needed.
JohnM10 is offline   Reply With Quote
Old 10-02-2012, 04:58 PM   #3
SubieNut09
Member#: 226080
05 Impreza
Thanks John.
Old 10-02-2012, 05:04 PM   #4
GrundleJuice
Member#: 165749
Steel plugs in aluminum heads plus lots of heat and you say anti seize its not necessary? Sounds like a recipe for disaster.
Anti seize certainly will not hurt as long as you keep it off the electrodes. Some dielectric grease in the boot that goes over the plug is good insurance against moisture/corrosion and arcing, too.
Old 10-02-2012, 06:29 PM   #5
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
^ This
NGK FR5AP-10 is the part you want. Subaru says it's the -11, which is too large of a gap, according to the FSM.
Counterfit is offline   Reply With Quote
Old 10-02-2012, 11:10 PM   #6
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I think the recommend gap is .006, I can't remember off the top of my head but I have a service manual somewhere is you need the specs on it
alt14 is offline   Reply With Quote
Old 10-02-2012, 11:15 PM   #7
Counterfit
Member#: 124254
"The Scoobinator"
That sounds awfully large small.
Edit:
Old 10-03-2012, 02:40 AM   #8
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Ive run both and the NGK has been better for me.
Bababou is offline   Reply With Quote
Old 10-03-2012, 12:01 PM   #9
JohnM10
Member#: 244231
Old 10-03-2012, 04:51 PM   #10
SubieNut09
Member#: 226080
05 Impreza
Thanks to everyone for all the help.
Bob.
Old 10-03-2012, 05:44 PM   #11
alt14
Member#: 271928
2014 WRX Limited
Edit:
I think I meant .6 lol I have to take a look
Old 10-03-2012, 05:56 PM   #12
Counterfit
Member#: 124254
"The Scoobinator"
Then I was right the first time, that's huge! You probably mean 0.06, which is still big, but not ridiculously so.
Old 10-03-2012, 07:02 PM   #13
alt14
Member#: 271928
2014 WRX Limited
I have no idea why I thought it was 6, I just looked it up, .039-.043 at 15.2ft-lb torque
Old 10-03-2012, 07:57 PM   #14
Counterfit
Member#: 124254
"The Scoobinator"
Then you want the FR5AP-10
Old 10-03-2012, 11:17 PM   #15
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
Originally Posted by Counterfit View Post
^ This
This.
I actually emailed Subaru Canada about why the Owners Manual called for the -11 plug when it's already at the high end of the range (and will generally grow with use) according to the FSM. As expected, they didn't really answer the question, just reiterated the FSM gap range
Saying all this, I still use the -11 plugs (dealer servicing to keep my warranty) and haven't seen any issues or excessive gaps at the end of their service life. Of course, a larger gap will be more of an issue if your electrical system is not up to snuff....
NH8991 is offline   Reply With Quote
