Tire & Wheel Forum sponsored by The Tire Rack |
10-02-2012, 09:05 PM | #1 |
Member#: 179684
Vehicle:2004 Sti Aspen White |
Is it safe?
Hey I wanted to know if it was safe to run a 235 45 17 tire on a 17x9 +42 rim... On an 04 sti..
Will the rim stick out too far out?
10-02-2012, 09:54 PM | #2 |
Member#: 274499
NESIC
Vehicle:1994 5.8T Cobra 755rwhp @ 16psi |
Should be ok, just slightly taller and wider than stock.
10-02-2012, 10:44 PM | #3 |
Member#: 179684
Ok thanks.. I have the tires on already just switching the rims up a bit.
10-02-2012, 11:06 PM | #4 |
Member#: 212639
TXIC
Vehicle:WRX= 13/SWP/SOLD '10 NC2 Miata |
Mild stretch but just pay more attention to your tire pressures and you'll be fine
10-02-2012, 11:18 PM | #5 |
Member#: 179684
Ok will do. Thanks for the heads up.
10-06-2012, 08:30 PM | #6 |
Member#: 72891
Vehicle:2018 STI 99 2.5RS 2dr - 2017 XV |
If you are lowered you may have to roll the rear.
10-06-2012, 10:32 PM | #7 |
Member#: 286408
Vehicle:WFC #952 Function:error! |
^^^ That is not a stretch by any means. 225/45 is a stretch but almost nothing. 235 is essentially square.
That setup may cause rubbing though thats quite a beefy setup even if it is on a +42 |
