Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Closed Thread
Old 10-02-2012, 10:16 PM   #1
bugeye1990
Member#: 331386
2002 wrx
wrb
Default socket size
What size socket is the bolt for the crank pulley? Im havin trouble gettin the last bolt out of my flywheel because i cant keep it from turning the engine
bugeye1990 is offline
Old 10-02-2012, 10:18 PM   #2
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
22 millimeter. To get the flywheel bolts out you can jam the flywheel teeth with a wrench or something between the teeth and the bellhousing. Don't worry about breaking it, you won't even scratch it.
tibug is offline
Old 10-02-2012, 10:39 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
When I don't know what size socket to use, I try every one in my collection starting from smallest to largest. Then I buy more and more and more and more up to sizes that would frighten a diesel engine mechanic. If you can't figure out this concept, you should lay down your wrenches forever and farm out all wrench turning work.
Unabomber is offline
Closed Thread
