Old 10-01-2012, 10:00 AM   #1
FastWrxWagon87
Member#: 333346
Default 03 wrx smoking and burnt oil smell
i ve Checked the oil every other two days for the past 1000 miles and its at the full mark but when i get on it hard i see and smell brunt oil after coming to a stop? 127,xxx, my 2.5 had the same thing going on and i had the oil seal replaced and it was good to go.
FastWrxWagon87 is offline   Reply With Quote
Old 10-01-2012, 10:06 AM   #2
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
valve cover leak dripping onto the uppipe? you're just going to have to look around with a flash light and see what it is.
tebriel is offline   Reply With Quote
Old 10-02-2012, 11:30 PM   #3
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Check the power steering level too. I just fixed mine, but it had gotten bad enough that you could smell and see smoke waiting at a stop light. The hoses can fail around your mileage, and leak onto the exhaust manifold. It was at the point of being a little embarrassing by the time I collected all the parts and set aside the time to fix it.
Dentt42 is offline   Reply With Quote
Old 10-02-2012, 11:41 PM   #4
cornercase
Member#: 306921
2004 WRX
Is the smoke coming from under the hood or out the exhaust? If it's out the exhaust, I'd suspect turbo seals. If the hood, then look for oil leaks. If your engine bay isn't clean, have it cleaned and then just watch if for a week. The oil leak should become apparent.
Eamon
cornercase is offline   Reply With Quote
Old 10-03-2012, 08:59 PM   #5
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
I have this problem exactly, and will be changing the valve cover gasket very soon
Boobaru03 is offline   Reply With Quote
Old 10-03-2012, 09:51 PM   #6
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
yeah just did mine, it wasn't too bad. See the latest valve cover thread.
