Closed Thread
Old 01-10-2013, 09:17 PM   #1
KCWRX03
Member#: 343003
2003 Subaru WRX
Default E85 On a 2003 WRX
Does anyone run E85 On there 2002-2003 WRX? What supporting mods should I place and how hard is it to do it yourself including fuel pump and injectors and do the lines need to be upgraded as well I assume also did anyone have major problems with their engine after doing this and does the 2.0 Boxer handle E85, thanks
KCWRX03 is offline
Old 01-10-2013, 10:03 PM   #2
ColdSoda
Member#: 200545
2008 SPEC B
The information you seek is available using the "search" feature... . also, see below:
NASIOC > NASIOC Technical > Engine Management & Tuning
E85 fuel FAQ
http://forums.nasioc.com/forums/showthread.php?t=803341
NASIOC > NASIOC General > Proven Power Bragging
The E85 Army Thread
http://forums.nasioc.com/forums/show...light=e85+army
Sounds like you could also spend some time reading the unabomber's manifesto
ColdSoda is offline
Old 01-10-2013, 10:16 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I've been running E85 for quite a while.
You need:
properly sized injectors
properly sized fuel pump
tune
you can do it yourself if you're familiar with tuning yourself and have all the necessary tuning tools. If you are not familiar with tuning, then take it somewhere that can tune you and have them do everything.
Concillian is offline
Closed Thread
