Old 10-03-2012, 08:38 AM   #1
dd91wa
Member#: 331036
2006 WRX STI
Default How to go LOW!!!
heyhey
i have a 2006 wrx sti and am wanting to lower it so the body sit's just above the tyre...im having no issues with the rear but the front seems to rub on the inside fender wall...
im running xxr 530 18x8.75 +35'S on 225's with coilovers so i can go low but my problem is i dont want it scrubbing in the inner fender well. whats the trick you guys are using in the states to get your hawk eye STI's so low without scrubbing like a mofo in the front?
this is where i am at atm....i could probably go maybe 5-10mm lower without it scrubbing but any lower the inner fender well scrubs like the middle of the tyre....should i just take out the inner fender well lining and go at it with a hammer bashing it out a bit where its rubbing to gain some more clearance?
and here is the rear which i want the front to sit like
dan
dd91wa is offline   Reply With Quote
Old 10-03-2012, 09:21 AM   #2
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
roll your fenders, and be sure to use a heat gun if you don't want your paint to chip off. then pull them out a bit at the top od the arch to get them where you want them. A bit od camber may help too. good luck!
ravenlunatic is offline   Reply With Quote
Old 10-03-2012, 09:32 AM   #3
dd91wa
Member#: 331036
2006 WRX STI
nah its not rubbing on the fender inner lip...iv already rolled my front fenders...its actually hitting the inner wheel well....ill pull one of the wheels off and take a pic if it makes more sence so you guys can see where its rubbing
Old 10-03-2012, 09:33 AM   #4
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
Roll the fenders, pull the fenders, remove fender liner, add camber and smoke cigarettes
Check out the hellaflush threads, you can get some good insight there
brew02wrx is offline   Reply With Quote
Old 10-03-2012, 09:36 AM   #5
DoogieSTi
Member#: 247023
2007 STi
^^ Unabomber Jr?
DoogieSTi is offline   Reply With Quote
Old 10-03-2012, 09:49 AM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
yet another one
ya shoulda bought a vw or a hunduha
Old 10-03-2012, 10:22 AM   #7
blessthekellen
Member#: 273859
MY98
WRX
I personally think the stance you have now is terrific.
blessthekellen is offline   Reply With Quote
Old 10-03-2012, 10:23 AM   #8
1VIPWRX
Member#: 107554
yellow
lol.. basically what he said.. am running 18x9 with 255 tire. i dont rub on the liners. only when i turn the wheel all the way to the left or right.
1VIPWRX is offline   Reply With Quote
Old 10-03-2012, 10:55 AM   #9
dd91wa
Member#: 331036
2006 WRX STI
yeah thats what im talking about, when you turn the wheel all the way to the left or right, is there any way to avoid that? apart from lifting it obviously
Old 10-03-2012, 01:01 PM   #10
altezza2impreza
Member#: 95516
2011 WRX
Step one: purchase vehicle with superb handling
Step two: purchase inferior replacement parts
Step three: alter vehicle to reduce handling/functionality
Step four: ?????????
Step five: profit
altezza2impreza is offline   Reply With Quote
Old 10-03-2012, 03:01 PM   #11
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
Remove or trim fender liner, spend profit on cigarettes
Old 10-03-2012, 04:38 PM   #12
sc00by4life
Member#: 97135
all those cars you are looking at rub.
period.
they all do. they can say they don't, but they do.
if you want to go low, get used to rubbing. if you dont want to worry about it, dont worry about getting any lower.
sc00by4life is online now   Reply With Quote
Old 10-03-2012, 04:45 PM   #13
801soap
Member#: 293652
period.
This!! ^ ha i rub like a mofo but its gonna happen if you want to live the low life!! Get used to it bra
801soap is offline   Reply With Quote
Old 10-03-2012, 05:20 PM   #14
12sechatch
Member#: 132458
Okie Dokie Fine
I hate everyone.
this world is going to ****.
carry on.
12sechatch is offline   Reply With Quote
Old 10-03-2012, 07:55 PM   #15
dd91wa
Member#: 331036
2006 WRX STI
its actually humorous how everyone carry's on about lowering a car :P my car is still very functional and still gets tracked....im not running ridiculous amounts of camber, and if anything having a better low center of gravity is going to be beneficial as long as it doesn't rub....
i do like the look of a stanced car, but i was just wondering how everyones doing it and if they were rubbing...pulling and rolling of fenders isn't going to solve my rubbing issue if i went lower because thats not where it would be rubbing if i went lower.
too low to track you say?
anyways i ended up lowering it a bit more (no rubbing) and got the height i wanted looks good now
Old 10-03-2012, 10:08 PM   #16
animigan
Member#: 282967
2011 wrx ltd (5door)
225s? Slim! I guess that's the price you pay...
animigan is offline   Reply With Quote
Old 10-03-2012, 10:25 PM   #17
bottles
Member#: 311522
2012 WRX
Icy Silver Metallic
Actually 225 is within his wheel width allowance. The wheel is a 8.75 and that tire fits up till 9" wide.
bottles is offline   Reply With Quote
Old 10-03-2012, 11:41 PM   #18
dd91wa
Member#: 331036
2006 WRX STI
i actually like the look of the 225's on these rims hey, its a little bit of stretch but nothing crazy...
Old 10-03-2012, 11:58 PM   #19
TAJR02WRX
Member#: 260936
2002 VF48 wagonnn
Psm
looks great, dialed in beautifully i might add!
TAJR02WRX is offline   Reply With Quote
Old 10-04-2012, 01:07 AM   #20
svxninja
Member#: 279510
02 Wrx
Got to pull them more
svxninja is offline   Reply With Quote
Old 10-04-2012, 08:05 AM   #21
dd91wa
Member#: 331036
2006 WRX STI
^^^ they arn't pulled at all, just will run a little bit of camber in the front and it will sit flush or tuck in if i want...goes to the alignment shop soon tho
Old 10-04-2012, 09:41 AM   #22
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
put some 255s on there and it will actually look mean! stretch is the weak sauce
07VTRex is offline   Reply With Quote
Old 10-04-2012, 10:45 AM   #23
dd91wa
Member#: 331036
2006 WRX STI
realistically ill be going maybe 245's nextm i think 255's might be too aggressive....i was already using these tyres with my 18x8's so thought i would continue to use them untill they wear out, tyres aint cheap over here haha
Old 10-04-2012, 10:51 AM   #24
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
agreed. theres no reason to waste perfectly good tires, so props for using them up first. i hate being wasteful! the difference between 255/35/18 an 255/40/17 is a couple hundred dollars, hence why i run 17" wheels (and lighter weight too).
Just for reference i am lowered on yellows, running 17x8.5 with 255s with roll/pull in the rear and absolutely nothing done to the fronts and i NEVER rub! and it even looks "aggressive", if your into that . So it can easily be done, you just have to have proper fitment
Old 10-04-2012, 11:43 PM   #25
TweekedXXII
Member#: 313727
2005 WRX Wagon
Aspen
Originally Posted by Uncle Scotty View Post
yet another one
Yet another bull**** post.
You should shut your mouth and post in threads that contain wankers that need to eat it.
Oops that's my inner voice detecting horse ****.
OP, you could pull the inner liners, do a little "massaging" then go to town with some good rubber coating..
TweekedXXII is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:16 PM.
