Old 10-03-2012, 12:03 PM   #1
salvi
Member#: 188132
Default STI OEM Oil Cooler in 02 WRX possible?
I'm getting my 02 WRX motor ready for my swap and I bought a new oil cooler. It looks like I received an 08-11 oil cooler instead of the 02 one. The 08-11 cooler is bigger than the 02 one, but it has the water lines in different spots and the metal line from the water pump will not match up.
If I wanted to run the upgraded year one, would it be as easy as just getting that year's line? Has anyone done this before? Thanks.
02 WRX oil cooler
08-11 oil coooler
salvi is offline   Reply With Quote
Old 10-03-2012, 02:29 PM   #2
StealthTL
Member#: 206912
2006 Forester XT
If the hardware fits and the only issue is the hose, use a longer hose and eliminate the metal tube and two of the four clips.
I did.
StealthTL is offline   Reply With Quote
Old 10-03-2012, 03:11 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
To call the newer one an "upgraded" one is laughable. If you want a real upgrade, get a standalone. Odds are your need neither as you are only supposed to be concerned about this if you have reason to be concerned. What are your oil temps? Do you know what the oil temp sweet spot is? Did you know running oil cooler than desired is bad?
Old 10-03-2012, 04:32 PM   #4
salvi
Member#: 188132
I'm not sure Unabomber since the motor is on the engine stand. Besides, I'm not going to follow any of your advice since your last clutch advice was to say the least, crap.
Old 10-03-2012, 04:37 PM   #5
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
The thermal rejection difference will be quite minimal to be honest between the 2 units.
If your oil temps are issue/ want to avoid oil cooling issues consider doing a external oil cooler.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 10-03-2012, 04:42 PM   #6
salvi
Member#: 188132
Ok, well I will be returning then. Thanks.
Old 10-03-2012, 04:50 PM   #7
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
omG. unabomber is right about everything! he wrote the manifest0.!!
nightcrawler60 is offline   Reply With Quote
