Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 10-03-2012, 12:15 PM   #1
echoe09
Member#: 286148
Default Only 2 out of 4 wheels turn
The drivetrain is 04 STi 6 speed, After lifting all tires up when i put it into gear only the passenger side tires spin and drivers side usually doesnt spin. When given gas the RL usually starts but FL only budges sporatically. This is also accompanied by on odd noise that seems to be coming from center diff on the trans... Cant hear it when im under the car but when im inside it occurs when i put it in gear and increases fequency as i accelerate (all while car is in the air) when im in the ground i dont hear any noises and car seems fine.
Could brakes be biting causing a unequal power displacement? Yes e-brake is released.
DCCD is set to default since i dont have a controller which always puts more power in the rear
Have video.. Ill work on uploading if it would be helpful.
Thanks for the help!
echoe09 is offline   Reply With Quote
Old 10-03-2012, 01:32 PM   #2
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Normal for open diffs. Put a little drag on the spinning tire and the other one will start to move.
bushflyr is offline   Reply With Quote
Old 10-03-2012, 02:53 PM   #3
echoe09
Member#: 286148
Same with the noise?
Alright thanks for the info!
Old 10-03-2012, 04:23 PM   #4
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Your title was misleading. I thought you thought all 4 wheels would turn when making a turn.
Ernest is offline   Reply With Quote
Old 10-03-2012, 04:26 PM   #5
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
That would be in the MR2 forums.
Old 10-03-2012, 09:46 PM   #6
echoe09
Member#: 286148
Lmao I see that now..
Wonder what that would be like.
I bet that would help with our understeer problem if they did!
Old 10-04-2012, 08:31 AM   #7
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
is almost always a poor choice of parts and a bad alignment
easily fixable
lots cry about this and then are when ya tell them what they are doing wrong
