Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 10-03-2012, 12:46 PM   #1
Whitetiger1
Member Sales Rating: (3)
Member#: 132765
NNJR -SCCA Legacy GT
#15 ESP Pro
Default Tri-State NY/NNJ - Racing Brake rear 316mm bbk for stock calipers-SOLD
SOLD!
Selling my Racing brake rear 316mm larger rotor kit for the stock calipers. the kit comes with 2 larger rotors, and replacement caliper brackets to extend and reuse the stock calipers and pads. this is a link to the kit as it is new. The rotors are nearly new. i bought them, to replace the original ones i got with the kit, at the end of February of this year and only put about 3k miles on them so no pad deposits or warping or even rust. HP+ pads were used with them. The extended brackets are in good shape too however there is 1 small exception. Over the course of having them, one bracket's screw holes were stripped. I repaired it by re-tapping to a slightly larger bolt(from M10x1.25 to M12x1.75), Due to the slightly larger bolt, the holes of the backing plate you would bolt it to would need to be drilled out slightly by about 2mm in diameter to fit the bolts. the other bracket still has the original holes in good shape. I will include the 2 larger bolts and the right size drill bit to make the install easy. you can see in the pics below the bracket with the bolts in them is the one i fixed up. I ran the bracket like this for over 10k miles with no issues in competition. works great.
This kit is a direct fit for the 05-09 LGT but other models can use it as well but the need the LGT rear calipers and LGT rear style pads.
This kit goes for $589+shipping. I'm selling for $425 shipped+paypal OBO.
PM to secure purchase
selling it also on legacygt.com here - http://legacygt.com/forums/showthrea...bk-193564.html
go there for the hi-res pics
Whitetiger1 is offline   Reply With Quote
Old 10-03-2012, 12:47 PM   #2
Whitetiger1
Member#: 132765
#15 ESP Pro
Old 10-17-2012, 10:22 AM   #3
Whitetiger1
Member#: 132765
#15 ESP Pro
Sold!
