Old 10-08-2012, 10:44 AM   #1
whitrzac
Member#: 229105
2001 Forester
Default 2001 outback LLbean?
There's an 2001 outback LL bean with 180k localy...
Are there any major issues I should look out for?
whitrzac is online now   Reply With Quote
Old 10-08-2012, 11:46 AM   #2
Airplay355
Member#: 213825
2013 BRZ
Make sure there aren't any dead hookers in the trunk...
Airplay355 is offline   Reply With Quote
Old 10-08-2012, 01:25 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
...or bags with dried leaves and white powder.
Seriously though? Get it inspected, check maintenance history. 180k is almost 200k, and 200k = timing belt, pulleys, tensioner, along with every bloody fluid to be changed. Check if it has a head gasket job, or if it leaks. 2.5 N/As tend to blow HGs every 100 000 miles...
Bluefoton is offline   Reply With Quote
Old 10-08-2012, 03:32 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Mrs. TiC drives one. Great car! It has 170K on it.
At this point in time the valve covers will start to weep, the rear muffler flapper valve likely died, and the sunroofs may not operate. Trans may have the automatic left hand turn hard acceleration click. it's becoming more common on those trannies that accumulate high milage. despite this it should be find for quite some time. The fix could be one of three things in the tranny, but I have not had a chance to tear into it.
Despite this it has been a great car.
Belts and hoses do at normal interval. There's no timing belt as it uses a chain, and honestly will likely outlast the rest of the car.
other than that you'll have your normal wear items such as ball joints, tie rod ends, and struts.
Turn in Concepts is online now   Reply With Quote
Old 10-08-2012, 08:23 PM   #5
whitrzac
Member#: 229105
2001 Forester
I test drove it at lunch today...
I know the guy that's selling it, I trust him to try and rip me off any way possible.
The car is $4k and needs struts, balljoints, tires, tuneup... There's rust bubbles forming around the rear fender...
When I first started it, it had a really rough idle at 4-500 rpm, I tapped the gas and it ran fine at 1.2k...
It's the cheapest I've seen a running H6 around here though.
http://madison.craigslist.org/ctd/3258569824.html
Old 10-08-2012, 10:18 PM   #6
Airplay355
Member#: 213825
2013 BRZ
$4k seems a little much to me, especially with it's issues.
Old 10-08-2012, 10:55 PM   #7
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
I wouldn't pay over $2000
cmk82600 is offline   Reply With Quote
