Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 01-22-2013, 04:18 PM   #1
alesx7817
Member#: 344258
2011 WRX STI AT
Default Can I cut and splice the donwpipe?
I bought invidia Q300 + downpipe at installation time, missed 10 cm long to fit all
My mechanic said it will amend the domwpipe with another piece of steel pipe
Said it will not harm or alter the functioning of the downpipe
Could someone confirm this?
You can cut the downpipe to make a Splice without impairing the functioning?
alesx7817 is offline   Reply With Quote
Old 01-22-2013, 05:44 PM   #2
bluemax189
Member#: 137405
20g
if you bought an invidia downpipe and invidia catback for the correct vehicle it should not need to be cut and extended at all.
bluemax189 is offline   Reply With Quote
Old 01-22-2013, 05:48 PM   #3
assasain
Member#: 323978
2004 WRX STi
Aspen white
I think my better half is telling me not to change the lengths of the tubing as that will adjust the overall performance by shortening or lengthening the original design. Therefore the airflow won't be manufacturer specs meant to flow through that pipe.
But that's just me overthinking this probably.
assasain is offline   Reply With Quote
Old 01-22-2013, 06:14 PM   #4
802-303
Member#: 283194
I have a feeling your dealing with a non-USDM car, and the downpipe you bought was for a USDM car.... I'm not sure about the 08+, but 02-07 had a longer downpipe for the JDM cars, shorter for USDM. If the same applies, and I'm reading your post correctly, you'll need to extend your downpipe....
802-303 is offline   Reply With Quote
Old 01-22-2013, 06:27 PM   #5
alesx7817
Member#: 344258
2011 WRX STI AT
My mechanic works with cars subaru mechanic, he is the first automatic picks
He had already pulled the mapping of my sti and analyze vai, I'm worried
So I wanted to install invidia Q300, but at the time, lacked a pipe about the size of donwpipe
I bought this product site
http://www.rallysportdirect.com/Invi...-2011-WRX-2011
Should not come one more piece of pipe to splice in another part of the original sti?
That part should not need to buy to use the downpipe? If the problem or remap the car's performance
Old 01-22-2013, 06:31 PM   #6
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Extending the length will not harm the car. Have him fix it and start enjoying your car.
Old 01-22-2013, 09:06 PM   #7
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
^^^^^^^^^^^^ this. it's a pipe that the exhaust gas travels. since it's all post-turbo, the only thing that will effect the performance is if you add something restrictive to the flow.
i think you got a jdm downpipe and a usdm cat back and that's why it's short.
dave_88 is offline   Reply With Quote
Old 01-23-2013, 10:42 AM   #8
alesx7817
Member#: 344258
2011 WRX STI AT
They can delete or close the topic, the mechanic was confused and reversed so the tips do not fit
This solved everything, in my sti invidia Q300 without installing downpipe
thank you
Old 01-23-2013, 11:03 AM   #9
Risko
Member#: 342526
2013 WRX Hatch
CBS
^ sounds like a great mechanic.
Risko is offline   Reply With Quote
