Old 10-03-2012, 07:39 PM   #1
dinggoo
Member#: 295432
2003 WRX
MBP
Default Hybrid build gasket questions
hey everyone ive been searching a bunch and cant really find my answer
So I have a 02 wrx with a 2.0/2.5 hybrid. The problem is i have a blown head gasket on the passenger side. I am going to be pulling the engine and replacing both head gaskets now my question is since i am only pulling the heads off and replacing the head gasket what other gaskets do I need. Im wondering if i can just get the ones i need instead of 150 when i only need a few.
as of now the only gaskets i can think of that i need are
all the exhaust gakets
tgv gaskets upper and lower
head gaskets
valve cover gaskets
what other gaskets should i get
dinggoo is offline   Reply With Quote
Old 10-04-2012, 08:34 AM   #2
biodude
Member#: 271720
you don't need both the upper and lower TGV gasket, you can leave the TGV's attached to the intake when you remove it. so just the lowers
the valve cover gaskets are rubber and may not need to be replaced if you don't tear then when taking the covers off that is,
you may want to have new cam seals on hand.
biodude is offline   Reply With Quote
