Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 04-25-2012, 09:02 PM   #1
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
Default Datalog Guru's 05 STI Problem
Hey all, to get right to the point I have a 05 sti tuned by JR at P & L Motorsports last year right before the car went into storage. Just took the car out and drove it for 250 miles and headed up to emissions I failed due to the evap and o2 monitors not being ready not a big deal so I decided to do some data logging. I'm having a hesitation at low load between 3-4K and hesitation at WOT arround 4K I'm not quite sure how to read the data logs and any info would be great. I'm thinking its a front o2 sensor going bad or a boost leak but I'm not not sure. I took 2 logs at WOT from 3-6800 RPM in 4th gear let me know what u tuning guru's think thanks.
UPDATE: Fixed the hesitation as the MAF scale was off causing the hesitation but still cant pass emissions as my EVAP and O2 are still not in ready mode no codes and no pending codes.
https://docs.google.com/spreadsheet/...ubW1ERFE#gid=0
https://docs.google.com/spreadsheet/...VVGpvd0E#gid=0
My mods are:
(93 Octane Pump Gas Tune)
COBB AccessPort
Stock VF39 Turbo
Cobb Catless Downpipe
HKS Carbon Ti Catback
APS Equal Length Split Pulse Headers
APS Uppipe with custom 38mm EWG (Tial MV-S)
APS TGV Deletes p&p’d by Grimmspeed
Grimmspeed EBCS
Grimmspeed p&p’d Manifold
Grimmspeed p&p’d Throttle Body
Grimmspeed 8mm Phenolic Spacers
Perrin Side Feed Fuel Rails
DeatschWerks 850cc Sidefeed Injectors
Walbro 255 Fuel pump
Perrin FMIC with Tial Q BOV
Perrin Turbo Inlet
Perrin AFTA MAF
KsTech 73mm MegaMAF CAI
Crawford AOS
Perrin Crank Pulley
spoolinej25 is offline   Reply With Quote
Old 04-26-2012, 01:43 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Please do not try to fit two problems into the same log.
Also, make your WOT pulls from 2500.
I'll look through the data some more and see if I can pick anything out.
Old 04-26-2012, 07:03 PM   #3
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
Just trying to give you guys a good idea on whats going on with the car maybe the hesitation at low load has something to do with the hesitation at WOT? Info on the logs would be great
Old 10-03-2012, 11:21 AM   #4
wrxed04
Member#: 67115
2005 STi
Did you remedy the issue with evap and 02 readiness? I have exactly the same problem...any ideas?
wrxed04 is offline   Reply With Quote
Old 10-03-2012, 06:20 PM   #5
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
Nope I still have not been able to get those two monitors in ready mode and I'm 99.9% sure its a tuning related problem. I was stage 2 before with cobb stage 2 flash and passed emissions fine, ever since I got protuned I've been having these problems. I know for a fact that when you are tuned they turn the rear o2 sensor off so what you can try is having your tuner turn the o2 sensor back on. If your catless you should get a code and if you do get the code all you need to do is install some spark plug anti foulers or wire in an MIL eliminator. I just had my tuner do that the other day and I'm catless and drove the car a few times with no CEL yet and monitors still not in ready mode. It's been hell trying to get this figured out if you come across any info or a fix please let me know. Also if you dont mind me asking what are u using for you fuel setup, injectors, rails, pump?
Old 10-03-2012, 06:27 PM   #6
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
Another reason why I know its tuning related is because there are no codes and no pending codes if there was a problem with the evap system you would get a CEL. gota be tuning related and I'm pissed trying to fix this. Do you have any codes or pending codes?
Old 10-03-2012, 07:43 PM   #7
6lug
Member#: 108817
Why not reflash the OTS map then go do the emissions test? ( I understand this won't fix the problem with the tune, just for emissions purposes). Then maybe get it tuned again. How long has it been stored?
Wait, I think the OTS stg2 turns the P0420 off...will that pass emissions or not?
6lug is offline   Reply With Quote
Old 10-03-2012, 07:48 PM   #8
Andrewxxcarlson
Member#: 316415
2006 WRX
Originally Posted by 6lug
Why not reflash the OTS map then go do the emissions test? ( I understand this won't fix the problem with the tune, just for emissions purposes). Then maybe get it tuned again. How long has in been stored?
I second this!
Andrewxxcarlson is offline   Reply With Quote
Old 10-03-2012, 11:19 PM   #9
wildt267
Member#: 161812
06 Wrx STi
CGM
How do you know for a fact? I researched this not too long ago and I remember reading a post by Bill from Cobb saying that one can only disable the influence from the rear o2 sensor in the speed density strategy. If you can in fact do this please enlighten me. I was unable to locate anywhere in accesstuner pro that would allow me to do so.
wildt267 is offline   Reply With Quote
Old 10-04-2012, 08:20 AM   #10
6lug
Member#: 108817
To disable O2, I *believe* go to Edit -> Advanced Parameters -> Then uncheck P0420.
Old 10-04-2012, 08:28 AM   #11
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
that doesnt disable the O2 sensor. It just removed the error report for removing the catalytic converter. The rear O2 is still used for a small percentage of your fueling adjustment.
By your logic, if you disable P0300, P0301, P0302, P0303, P0304 would stop the car from ever misfiring.
OP, Open up Accesstuner Race and hit CTRL+A
Select the Toggles (Base) tab and see if "Monitors Self Test (Diagnostic Purposes Only)" is checked. If ti is, uncheck it. If not, check it.
Old 10-04-2012, 09:18 AM   #12
6lug
Member#: 108817
Flawed logic is the problem. Thanks.
Old 10-04-2012, 10:44 AM   #13
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
Car wont run right if at all, I havent tried that yet but i think I have too many things done to the car for a OTS STG2 map to work for me.
Car has only been stored over the winter months maybe 4 months max
All I know Is when I went back to my tuner for the 3rd time for this same problem and told them to turn that rear o2 sensor back on we got in a conversation and was told by him that when they tune they turn the rear o2 off because its no longer needed. I'm also catless which in theory with that sensor on I should throw a code but still have not?
I'll have to see if this is checked or not
Datalog - 05 STi - PXT Stg2 (high boost) - 3rd gear - 93 octane - Thoughts? xjohnx AccessPort 11 09-07-2010 10:31 PM
Datalog - 05 STi - PXT Stg2 (high boost) - 3rd gear - 93 octane - Thoughts? xjohnx Open Source Reflashes 4 08-19-2010 03:58 PM
05 STi problems with Diffs or DCCD? z3coupe Transmission (AT/MT) & Driveline 5 11-12-2007 05:29 PM
Accessport 05 sti problems/questions?? jy04 Engine Management & Tuning 1 08-02-2005 10:47 PM
HKS Carbon Ti Exhaust 05 STi *PROBLEM* essteaeye Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 06-20-2005 09:09 PM
