Old 10-10-2012, 06:51 PM   #1
lj8915
Member#: 329252
2012 Subaru WRX
Default Logs with Torqued Performance stage 1, 2012 wrx, 91 octane
Do they look good? To me they look good, but I don't know much about logs. I only have crappy 91 california gas so it's good to see zero knock, except on the last one where I shifted from 2nd to 3rd quickly. Could the quick shift had made the knock show up? Because knock wasn't anywhere else or on the other two logs.
https://docs.google.com/spreadsheet/...2ZEQl9ScTdlZXc
https://docs.google.com/spreadsheet/...3VIVjhGMEtocFE
https://docs.google.com/spreadsheet/...WpqdHI5OHZTeHc
lj8915 is offline   Reply With Quote
Old 10-10-2012, 09:52 PM   #2
mikeydrives1
Member#: 262117
Everything looks good and healthy to me. I do have a few thoughts to share though.
DAM was 1 and knock was next to nothing except that last run there was some fine knock learn. Just about any car that ive observed or done logs for an extended period of time on (in your case, 3 logs) , i manage seeing fine knock learn. Im fairly sure that in your case its just due to a little heat soak. Its not making absurd or rash adjustments by looking at those numbers, so its normal in my eyes. But theres no need to be overly alarmed over it... The ecu is programmed this way specifically to combat any kind of knock, in this case, which it did and it went right to 0 again. So your engine is responding naturally to what happens with the type of boost you are running on the octane gas you use with a likely a little heatsoak.
The only true concern i have is that i see your Injector duty cycle is nearly maxxed out on your runs when you reach peak performance. Now this is fine for now, but if you ever wanted to get more boost in there or change anything up, you will need to upgrade to larger injectors.
Other than that, everything seems perfectly fine to me.
-Mikey.
mikeydrives1 is offline   Reply With Quote
Old 10-11-2012, 11:33 AM   #3
Delphi
Member#: 239335
Send these logs to Eric and he will tell you if they are good or not and make adjustments if needed.
Delphi is offline   Reply With Quote
Old 10-11-2012, 03:07 PM   #4
lj8915
Member#: 329252
2012 Subaru WRX
The logs look great. The shift can trigger the knock sensor like that.
