Old 09-08-2002, 12:17 AM   #1
edkwon
Member#: 453
2014 Audi S4 B8
2016 Porsche Cayman GTS
Default Whats a good aftermarket clutch that isn't too stiff on the clutch pedal
I'm looking for an aftermarket WRX clutch that can handle some extra power, is more durable than stock, but doesn't feel mega rock hard when you step on the clutch pedal, are there any good choices?
Ed
edkwon is offline   Reply With Quote
Old 09-08-2002, 12:25 AM   #2
STi_Pete
Member#: 14576
2002 WRX Sedan
Ed Try calling Adam @Z1auto.com I believe he has an Exedy twin plate clutch in stock....
Twin Plate Advantages
Maximum Clamping force
Minimum increase in pedal effort
Lightweight flywheel included
The only drawback is price .... but for what you get you can't even say that
STi_Pete is offline   Reply With Quote
Old 09-08-2002, 07:12 AM   #3
edkwon
Member#: 453
2014 Audi S4 B8
Thanks for the tip!
Ed
Old 09-08-2002, 02:48 PM   #4
turboman31
Member#: 13909
WR Blue
Post cluch
turboman31 is offline   Reply With Quote
Old 09-09-2002, 05:21 PM   #5
Z1 Performance
Member#: 9327
We stock all the Exedy units..how much are you looking for the clutch to hold torque wise?
adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 09-09-2002, 06:37 PM   #6
jlogan9
Member#: 15511
I am also interested in a new clutch, but I have heard rumors that a new clutch puts undue stress on the transmission. Is this just a rumor, or is there any truth behind it?
Also, which clutch would be good for about 300-350 hp range. I am not sure of the torque specs.
Jeff
jlogan9 is offline   Reply With Quote
Old 09-09-2002, 11:15 PM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I am using the Exedy racing clutch instead of my old ACT, and the pedal effort is much less than the ACT due to a difference in the pivot point.
It is holding as much as 15 psi on a 2.5L so far, with 11 psi launches if I dump it to break the tires loose. If I slip it intentionally on launch at 5,500 rpm it keeps slipping. Same with the ACT.
ImprezaRS dot com is offline   Reply With Quote
for a good Subaru mechanic that isn't in a dealer Sco09 Newbies & FAQs 1 05-10-2010 10:06 PM
What are some aftermarket parts that are compatible with the WRX AND STI? disque71 General Community 1 09-28-2006 02:27 PM
Some good aftermarket rotors that fit oem specs??? saicwrx Brakes, Steering & Suspension 7 12-29-2005 01:10 PM
Whats that sound when letting up on the clutch? WRX_man20 Transmission (AT/MT) & Driveline 2 05-23-2002 01:15 PM
M2/DMS 40mm... too stiff for the street? WRX Power Brakes, Steering & Suspension 11 03-14-2002 11:36 AM
