Old 10-04-2012, 11:35 AM   #1
avionator
Member#: 210482
Default difference between AT and MT 2.5 engine?
any difference between the engines used in the automatic cars vs stick shift? I need to replace my engine on my 2009 2.5i manual transmission, but i'm mostly finding engines from cars equipped with auto.
Any reason an auto engine wouldn't work on a manual car? Obviously i'd have to switch over the flywheel/clutch... is that possible on an engine from an auto? Or is there something weird...?
thanks!
avionator is offline   Reply With Quote
Old 10-04-2012, 12:52 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I believe the ECU has auto or manual transmission components in it. Basically what I'm saying is that I think the ECU differs slightly from AT to MT engines.
chazly413 is offline   Reply With Quote
Old 10-04-2012, 01:24 PM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
thanks!
Difference in idle speeds by the ECU and the TCUs are obviously different. Also you would need to use a manual flywheel. as long as your ECU plays with that engine it will control it as programmed auto/manual isnt a factor
GEE-OTTO is offline   Reply With Quote
Old 10-04-2012, 05:36 PM   #4
avionator
Member#: 210482
any reason why my ECU from my manual wouldn't get a long with an engine from an auto? I'd be replacing with an engine from the same generation, and no turbo or any other changes. swapping the flywheel from my engine to the other engine shouldn't be a huge deal, right?
Old 10-04-2012, 05:56 PM   #5
4doors4hp
Member#: 331791
thats a weird question.. maybe try finding a manual ecu?
4doors4hp is offline   Reply With Quote
Old 10-04-2012, 06:56 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
He has one. His car is a manual. He's asking if an engine from an auto car will work w/his manual car. The only difference I know of (beside the flywheel) is the timing belt guide. Auto's don't have them, manuals need them. It's a small piece that bolts to the oil pump so the timing belt won't jump teeth in the event that the engine spins backwards.
You'd have to inspect the engine harness connections to make sure that they will jive with your chassis harness.
Old 10-04-2012, 07:55 PM   #7
avionator
Member#: 210482
Originally Posted by yarrgh View Post
...The only difference I know of (beside the flywheel) is the timing belt guide. Auto's don't have them, manuals need them. It's a small piece that bolts to the oil pump so the timing belt won't jump teeth in the event that the engine spins backwards.
huh, definitely didn't know that! that's a VERY helpful thing to know. also, it would SUCK to order an engine and then notice the harness is different. i'll be calling somebody who deals with subies to find out. I'll post the answer when i get it.
Old 02-26-2013, 06:41 PM   #8
07Scuby
Member#: 293000
Just wondering if there were any issues with your swap. I'm going thru a 09 auto into a 07 manual now. If I need harness swap would like to know before hand. Thanks
07Scuby is offline   Reply With Quote
