Old 10-04-2012, 01:41 PM   #1
gregmyer
Member#: 330174
2002 wrx wagon
black
Default top hats help.
i am redoing the suspension on my 02 wrx wagon. i have my spring and shocks + various other bits and bobs picked ou but i was wondering what i should do for top hats. more so the front, i think i have already decided on group n for the back. i was thinking to sue the Whiteline COM C, good, bad any opinions.
list of what is going on.
ebac pro springs
Rear Subframe - lock bolt kit
Rear Diff - front support lock bushing
Front Control arm - lower inner front bushing
Front Control arm - lower inner rear bushing (anti-lift/caster correction) COMFORT
Both Sway bar - link assembly extra heavy duty alloy
gregmyer is offline   Reply With Quote
Old 10-04-2012, 01:47 PM   #2
gregmyer
Member#: 330174
2002 wrx wagon
black
The shocks are koin yellows
Old 10-04-2012, 02:51 PM   #3
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Group-N tophats front and rear or Whiteline Com-C front and Group-N rear.
With the Koni inserts, you will want a better spring. Perhaps the Racecomp Engineering 'Blacks' or Swift Spec-R or probably better, the Swift Wagon Springs.
Replace the trailing link bushings as well. For now, you can leave the lateral link bushings alone.
Old 10-04-2012, 07:13 PM   #4
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
What is the main thing Group N tophats address over stock? Body Roll?
ScubaruImpreza05 is offline   Reply With Quote
Old 10-04-2012, 07:50 PM   #5
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Deflection. You want to limit how much the suspension as a whole will tend to move and cause your settings to go outside of those parameters.
Or to put more simply: maintain better overall handling and control.
Old 10-04-2012, 08:50 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
foerget the rear group n tops...they do nothing
the fronts are the very most important
Old 10-05-2012, 12:59 PM   #7
gregmyer
Member#: 330174
2002 wrx wagon
black
Tanks for the advise. So the rear group n tops aren't that important? What about camber in the rear end? How much will I loose? What would be the best method to recover it?
Old 10-05-2012, 01:49 PM   #8
haberkorn
Member#: 97732
2004 STi
65 Nova [email protected]
If your that concerned about camber and getting it set just buy camber bolts for the rear. Wagon owners do it all the time when they put sedan suspension on.
haberkorn is offline   Reply With Quote
