Old 10-04-2012, 01:41 PM   #1
awd-turbo
Member#: 167551
02 wrx
Default timing belt issue
its been a while since i have posted here.... this is the situation.. sold house. building new one.... gf pregnant... car (2002 wrx) with 215k on it.... dont have a garage and dont want to go to a stealership right this second...
looks like the timing belt jumped or something failed... blew out and shattered what looks like a large plastic gear. i am no really sure. i havent spent much time in this engine. is this an interferance engine? why did subaru make part of the timing belt(whether it is a cam gear or some other part of the timing belt) plastic...even if it is a pull.... what the ****....
is my engine done?
awd-turbo is offline   Reply With Quote
Old 10-04-2012, 09:08 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
yes, its an interference engine that has VERY little tolerance for screwing with the timing system... It would be highly unlikely that you didn't destroy valves/heads/pistons/cylinders.
Obvious question is when was the timing belt changed last? What else was changed?
Yeah, the timing sucks, but think of it this way, she had a good run at 215k miles at least!
Old 10-04-2012, 09:25 PM   #3
biodude
Member#: 271720
engine done.. maybe not. Valves, probably yes.
by the way. Been there, done that.
biodude is offline   Reply With Quote
Old 10-05-2012, 12:32 AM   #4
bako
Member#: 226211
2002 impreza WRX JDM
blue
damn, need new heads. I'm sure there is nothing with shortblock
bako is offline   Reply With Quote
Old 10-05-2012, 08:26 AM   #5
biodude
Member#: 271720
In my case my a cam seized, causing the cam gear to assplode. I ended with one shot head and just about every valve bent on both sides. No visible valve to piston contact.
Old 10-05-2012, 09:15 AM   #6
awd-turbo
Member#: 167551
02 wrx
yea biodude.... thats the **** that exploded.. i dont know what happened or why, havent had time to look and i wont until feb or march...
i did the timing belt at around 140k... replaced belt, tensioner, water pump.. thats it.. tensioner was fine, but i replaced it anyways.. everything else looked great. i mean the belt itself was not missing any teeth at all, and wasnt stretched that bad....
Old 10-05-2012, 09:21 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
take the cam cover off on that side and look at the area
Old 10-05-2012, 09:58 AM   #8
biodude
Member#: 271720
here was the source of my problem, the gear exploded because when the cam locked up, the timing belt pulled tight and took out the cam gear.
Old 10-05-2012, 11:10 AM   #9
Member#: 301037
2004 Forester XT
Sorry to hear about your problems. Chances are that the valves got damaged to some extent. I would take it somewhere and have them checked you may have got lucky but, chances are if it was bad enough to break the pulley then the valves are damaged.
art@grimmspeed is offline   Reply With Quote
