Closed Thread
Old 10-04-2012, 03:29 PM   #1
imprezame321
Member#: 334145
Default Interior clock ('02)
I checked the fuses and replaced with brand new ones it's still not working. Wasn't sure if it's the wiring, but had that checked out and it looks good. No clue what the problem is. What else should I check for?
imprezame321 is offline
Old 10-04-2012, 06:56 PM   #2
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
There is a small resistor/circuit on the back of the clock that probably has a break in it. If you are adept at soldering, you could attempt to fix it.
Big-E is offline
Old 10-04-2012, 07:25 PM   #3
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Even if you're hamfisted it's rather easy if you have the right tools. First time I ever soldered something was to repair the clock in my '02. There's an older thread about exactly which resistor is prone to breaking the solder connection; search for it OP.
OrbitalEllipses is offline
Old 10-04-2012, 07:50 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please use the search, there are a bunch of threads about the clock and how to repair it.
Mulder is offline
Closed Thread
