#1 |
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
NWIC
Well ... A new color anyway.
Adding to the already popular Red and Black is the NEW Blue. ![]() ![]() Click HERE to check out the turbo inlet hoses for 2002-2007 WRX and 2004-2013 STI Click HERE to check out the turbo inlet hoses for 2008-2013 WRX and 2005-2009 LGT ![]() ![]() MSRP > $229.99 Key Features SMOOTHER AIR FLOW TO TURBO The PERRIN inlet hose is perfectly smooth on the inside and has a significantly larger internal diameter than the OEM part. The increased air flow by removing the pleats found in the OEM hose makes more horsepower, decreases turbo spool time, and improves acceleration. SS INTERNAL SUPPORT WIRE The PERRIN inlet hose is reinforced with a stainless steel support wire that is embedded within the silicone layers. The support adds rigidity to the hose and prevents collapse when used with restrictive filter elements and large turbo applications running extreme amounts of boost. LARGE HIGH FLOW SPIGOTS All spigots on the PERRIN inlet hose are 1/2"ID for maximum flow from crank case vents and other vacuum connections. All connectors used on our hoses are glass reinforced nylon (rated to 400 degrees F) which will withstand engine bay temps found from normal driving to extreme racing conditions. BLOW OFF VALVE CONNECTION The PERRIN inlet hose has a machined aluminum insert which is bonded into the layers of silicone, giving you a solid blow off valve hose connection and makes installation go even easier. 5 YEAR WARRANTY PERRIN Performance warrants to the original purchaser, all PERRIN products to be free from defects in material and workmanship within a sixty (60) months period from the date of purchase. In Stock NOW Click HERE to check out the turbo inlet hoses for 2002-2007 WRX and 2004-2013 STI Click HERE to check out the turbo inlet hoses for 2008-2013 WRX and 2005-2009 LGT Wholesale Clients Please Contact Your PERRIN Sales Rep For More Details. "Legal in California only for racing vehicles which may never be used upon a highway"
#4 |
Member#: 270569
Hi, I am having a problem with my Perrin silicone intake in that it is leaking around the ports to all except the bov connection. Mine looks different to the ones you have above in that the ports are shaved off?
![]() Last edited by Harey; 05-05-2013 at 09:19 PM. |
