Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-04-2012, 06:59 PM   #1
4doors4hp
Member#: 331791
Default FrankenMotor myths/truths help?
so theres alot of threads on here.. but so many get off topic and i cant find the right answer.
i drive a ej251 subaru 00 legacy gt wagon bh b4.
ive read swapping heads isnt a good idea?.
but then in others, i read swapping ej22 heads, and having the dual port exhaust manifold is actually fairly well for a quick cheap N/A power gain, true or false?.
also, Phase I ej22 have the dual ports? or phase II?
another one, does it matter if the motor is an interference / non-interference ej22?
id like to do this swap, but really need to weed out the BS.
i understand that the compression is increased. just help me out please. or direct me to helpful reads/threads.
thanks.
4doors4hp is offline   Reply With Quote
Old 10-04-2012, 07:37 PM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
If your car is already a 2.5, then focus on things like cams, phenolic spacers, etc. The frankenmotor is great for us 2.2 guys, but bastardizing a 2.5 for the bump in CR is not worthwhile.
cal_look_zero is offline   Reply With Quote
Old 10-04-2012, 08:29 PM   #3
4doors4hp
Member#: 331791
Thank you. Nice and easy. Now for phelonic spacers, what benefit does that yield?
And would swapping.out for a ej253 block lower my compression as well as having a semi closed block allow me a moderate boost setup, (6-10psi).
Old 10-06-2012, 02:20 AM   #4
4doors4hp
Member#: 331791
Bump.
