Old 10-05-2012, 04:58 AM   #1
20g07wrx254
Member#: 306217
2007 wrx
white
Default shifter stuck?? help
So i was driving home from work tonight and right before my driveway i tried shifting from 3 to second and the shifter was stuck?? there is no movement what so ever.. Havent been on the car hard as i am still in break, and dealing with oil leaks, and currently untuned... I.managed to get it into first somehow to get it up the driveway... Cant move it at all now... Please help
20g07wrx254 is offline   Reply With Quote
Old 10-05-2012, 08:56 AM   #2
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Bleed the clutch, then report back.
Counterfit is offline   Reply With Quote
Old 10-05-2012, 12:08 PM   #3
20g07wrx254
Member#: 306217
2007 wrx
white
Will try but the clutch still feels the same
Old 10-06-2012, 09:57 AM   #4
STIll inspired
Member#: 248431
i would imagine it is a mechanical defect. the clutch shouldn't be the issue. check your fluid and if that looks normal then i would suggest making an appointment with subaru. (may want to take a look at the linkage too but that would be a longshot for this issue.
STIll inspired is offline   Reply With Quote
Old 10-06-2012, 03:48 PM   #5
20g07wrx254
Member#: 306217
2007 wrx
white
I went out today and started the car it goes in every gear but second....
Old 10-07-2012, 09:15 AM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
sounds like lots of work's been done, start from the last things done to the engine/trans related area and work back...
Was the trans removed for anything? could linkage have come loose?
Drain the trans into something clean... find any chunks on the plug? if not, something else..
All the easiest before the expensive stuff starts...
