Old 10-04-2012, 10:22 PM   #1
ToddMcF2002
Member#: 135007
2002 Wrx Sedan
Default Bugeye 17x9 et42 Handling?
I'm thinking of 17x9 either Rota DPT or Mach V Awesome. I'm leaning towards the latter for brake cooling. I want an opinion on how its going to handle compared to a 17x8 before pulling the trigger. Also need tire suggestions please. I'm willing to roll but not pull and I do NOT plan to slam the car (at least an inch of gap expected).
Other supporting mods:
QRack 11.5:1
Tarmac 2 Coilovers (500F/400R)
Ground Control Front Camber plates, Cusco rear camber plates
Whiteline F/R 24mm adjustable
Brembo's F/R with DBA 4000 rotors, stainless lines
Primary use - HPDE
Thanks!
ToddMcF2002 is offline   Reply With Quote
Old 10-04-2012, 11:52 PM   #2
yazel
Member#: 215344
2004 STi
STU/DD Prepped by TiC
Sending you a PM on my opinion of the 17x9 Rota DPT et42
yazel is offline   Reply With Quote
Old 10-05-2012, 12:01 AM   #3
mowgli29
Member#: 203438
I run DPTs in that size. Tires are 255/40-17. I've done some very minor rolling in the rear. I've got about the same size fender gap and my spring rates are 400/400. I also run ~8mm spacers up front.
During normal daily and spirited driving I have NO issues. Once in a while (very seldom), I'll find a BIG bump or pothole that compresses one of the rears enough to scrape a little strip of rubber off the tire.
IMO, definitely get the 17x9. You'll have no issues if you run a 245/40 and/or actually roll your rear fenders all the way.
EDIT: I can't give a direct comparison in handling to a 17x8, but just remember: any time you increase track (width), you effectively increase roll stiffness. You might have to put up with a bit more bump steer, but that's a worthwhile trade, IMO!
EDIT 2: For tires, assuming you want streetable ones (not slicks), I think the Potenza RE-11, Ventus R-S3, Ecsta XS, and Direzza Z1 Star Spec are still the best summer tires around. Star Specs seem to be dominating my local autocross, and are almost as good as RE-11 for WAY LESS MONEY. I've owned the Star Specs and the Ventus R-S3; both are great tires, but I think the Star Specs had a slightly more solid feel (less squirmy).
mowgli29 is offline   Reply With Quote
Old 10-05-2012, 12:29 AM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the 17x9 +42 is likely the best size with a 245/40
a 255/40 may be problematic
the 595rs-r in 235/40 may be a good way to go if ya want to drop the gearing a lil
Old 10-05-2012, 07:40 AM   #5
ToddMcF2002
Member#: 135007
2002 Wrx Sedan
Thanks for the feedback guys. I think I'll start off with the 245's then. I know the Mach V's clear Brembo without a spacer. Not sure about DPT?
Old 10-05-2012, 12:53 PM   #6
Craig4g63
Member#: 217175
2003 WRX
I went from a 17x8 rota with a 235/40 RS2 to the 17x9 Mach V with a 245/40 AD-08. Feel and over all grip was noticeably improved. Turn in was quicker, the ride was better, the tire is quieter, and noticeable less tramlining.
I did have to roll the rear, they would rub on large bumps.
Craig4g63 is offline   Reply With Quote
Old 10-05-2012, 01:45 PM   #7
ToddMcF2002
Member#: 135007
2002 Wrx Sedan
OK...... Ordered the Mach V Awesomes. Now I need the 245s. Primary use is HPDE so who has the grippiest? Dunlop Direzza Z1 Star Specs? Hankook Ventura RS2? Others?
Old 10-06-2012, 11:19 AM   #8
piripi
Member#: 178410
2006 WRX Wagon
CGM
Direzzas and RS3 would be my 2 preferred choices. Kumho XS its a good tire if you can find a good deal. Falkens have fallen behind. Yoko I don't think price difference its worth it. RE11 are great but dunlops and rs3 are way cheaper offering same grip.
piripi is offline   Reply With Quote
Old 10-06-2012, 04:04 PM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
i didnt think the rs2 tires were very good
Old 10-06-2012, 09:06 PM   #10
ToddMcF2002
Member#: 135007
2002 Wrx Sedan
Ok Star Specs in the lead. Anyone else?
Old 10-06-2012, 09:32 PM   #11
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I run the same wheels with 245/40 R17 RS3's and have found them to be a great tyre, I haven't tried the star specs though.
JDwhiteWRX is offline   Reply With Quote
Old 10-06-2012, 09:42 PM   #12
mowgli29
Member#: 203438
Do it. You won't find a better tire for the money.
Message Board Statistics All times are GMT -4. The time now is 08:28 AM.
