Welcome to the North American Subaru Impreza Owners Club Friday December 26, 2014
Old 10-04-2012, 11:52 PM   #1
fox_212
Member#: 322902
2003 16G-XT'd WRX
Default injector o-ring question
Hey everyone,
I'm installing DW 650cc injectors along with other stage 3 parts, and I have a question about the o-rings: The stock injectors have a "o-ring"/spacer thing just below the upper o-ring (the fuel rail one). Its got kind of a u-shaped cross section. Google stock wrx injectors and you will see them.
My DW injectors came with just a thicker o-ring where the spacer thing was on the stock injectors. The pics of them on rallysportdirect.com show the o-rings clearly. Which do I use, thicker o-rings or spacer things? The DW injectors have a slightly longer body, and the o-ring they came with is shorter than the spacer, which makes them just about the same length as the stock injectors with the spacer. I'm leaning toward the o-rings that came with the new injectors at this point.
thanks very much for the help
fox_212 is offline   Reply With Quote
Old 10-05-2012, 01:01 AM   #2
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
It's hard to read and understand what you really mean.
3 o-rings per injector
Small at the top
Grooved in the middle (lower them the upper)
Fat at the bottom.
Pics of what you have would help.
Regarding injector physical size.
Light blue and pinks fit the 02-05 rails perfect providing nobody bent the fuel rails during removal.
I believe the 06 and up top feed Dark blues are slightly shorter in length.
JRsleeper is offline   Reply With Quote
Old 10-05-2012, 01:30 AM   #3
fox_212
Member#: 322902
2003 16G-XT'd WRX
Ya, sorry for being confusing...here is a pic. Left is DW 650cc, with middle o-ring. Right is stock injector, with spacer thing.
Old 10-05-2012, 09:03 AM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
you can use either one, its to seal out dust, etc from getting to the top o-ring when seated in the rail.
fastnoypi is offline   Reply With Quote
Old 10-05-2012, 12:10 PM   #5
fox_212
Member#: 322902
2003 16G-XT'd WRX
Ok, thanks for the confirmation, thats what I was thinking.
Whoa, 4-digit member number! nasioc OG haha Thanks for the help
