Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 10-04-2012, 11:42 PM   #1
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
Default 05 STi compression test numbers, should I bother with a leakdown?
Hey guys,
So ive been having a strange issue where my 05 sti doesnt always engine brake while decellerating. IAG said that among other possibilities, it could be a low compression problem, which prompted me to get a comp. tester and find out. Here were my numbers:
(cold engine, about 500ft elevation, all plugs removed, WOT, ingition fuse pulled)
124,125,125,124
Im very happy with the consistency, however these numbers seem a bit on the low side. I know with the engine warmed up the #'s might be higher, but my question is should I be concerned? And do you think its worth performing a leakdown test?
thanks,
Nate
rolzrex is offline   Reply With Quote
Old 10-05-2012, 12:01 AM   #2
wayoutwest
Member#: 14379
2007 Acura
gray
If these were cold numbers i wouldn't be alarmed. The consistency is more important. What say everyone else?
cheers,
dave
wayoutwest is offline   Reply With Quote
Old 10-05-2012, 12:42 AM   #3
STIBungy
Member#: 51684
You're at 4330 ft alt. Your compression numbers will be lower than someone who's at sea level. When I did a comp test on mine, I was at 115 across the board. I'm about 1000 higher in elevation than you.
STIBungy is offline   Reply With Quote
Old 10-05-2012, 09:22 AM   #4
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
oh sorry stibungy I guess I need to update my info haha. I dont live in utah anymore im in pennsylvania now, near gettysburg.
